For anyone not familiar with what IRISYS did to enhance their low resolution camera images, I attach an image showing what they achieved.
IRISYS were working with a low resolution 16x16 pixel pyrometer chip that needed a lot of interpolation to achieve a useful image.They interpolated from 16x16 up to 128x128 ! As many readers will know, interpolation adds no true data to an image, it just takes the values of adjacent pixels and inserts virtual data in the midpoint between the two. Depending on how well interpolation is implemented, it can be challenging to spot in a processed image, especially if other image processing algorithms to remove sharp transitions are in use.
In a visible light camera you use a resolution chart to see the true imager resolution. This gets below any interpolation that may be in play. Sadly I have no such chart for use in the thermal domain.
A thought to consider.......
FLIR may be using sophisticated interpolation, and other image processing techniques, that may challenge us to determine whether the microbolometer is native 80x60 or 160x120........ If this is the case, they have done a very good job
If they are operating a X2 interpolation and we cannot truly see such in the real world, we are unlikely to have issues with the images that the camera produces in daily life
If our tasking is so demanding that it needs 160x120 physical resolution, then we should be able to clearly see the image degradation when compared with a known 160x120 thermal camera.
If not.....be happy
Aurora
