Author Topic: Use thermal camera for android skype?  (Read 1683 times)
Offline ConureTopic starter
« on: February 15, 2020, 11:58:54 am »
Is there any way to use thermal cameras for communication software like skype on android devices?
Offline Ultrapurple
  • Just zis guy, you know?
    • Therm-App Users on Flickr
Re: Use thermal camera for android skype?
« Reply #1 on: February 17, 2020, 06:34:11 pm »
Are you trying to use it for communication or as a remote surveillance device?
Rubber bands bridge the gap between WD40 and duct tape.
« Reply #2 on: February 17, 2020, 07:22:02 pm »
Talking on skype or facebook.
Offline IwuzBornanerd
« Reply #3 on: February 17, 2020, 11:30:27 pm »
You will probably have to do it yourself.  But it might be simpler to do on a real computer running Linux. :)   The closest thing to that I have seen (but I have certainly not seen everything) is a "driver" some of the forum members wrote for the FLIROne on Linux using v4l2loopback in the early days of [IIRC] the "Question about FLIR One for Android" thread.
v4l2loopback creates virtual video devices in the /dev directory & these can be written to & read by video4linux compatible programs which would normally read or write from/to hardware devices.  I tried unsuccessfully to use its predecessor "vloopback" once but have not used the current package.
According to one respondent on this page, v4l2loopback should be installable on Android...OR at least Androidx86:
    https://groups.google.com/forum/?_escaped_fragment_=topic/android-x86/MGjbgooOsyM#!topic/android-x86/MGjbgooOsyM
You would have to write an app that would write the thermal camera output to the virtual video device created by v4l2loopback & the Skype app would have to be able to select that device for input rather than the phone's camera.
« Last Edit: February 17, 2020, 11:33:30 pm by IwuzBornanerd »
I am not opposed to exercise, unless it is an exercise in futility.
Offline Vipitis
  • aspiring thermal photography enthusiast
« Reply #4 on: February 18, 2020, 12:17:42 am »
there is this certified app: https://play.google.com/store/apps/details?id=de.killig.remotethermalcam
it streams to a local machine with the server running. you could than screencap that for a video call via skype I guess.
Offline tonykids
« Reply #5 on: February 18, 2020, 06:49:48 am »
You can use screen sharing feature.
When making a call , select the "more..." button and "screen sharing", run the origin thermal camera software-fullscreen. :)
Offline Ultrapurple
« Reply #6 on: February 19, 2020, 01:25:54 pm »
Use something like an old fire camera with analogue out and a cheap USB video capture device - that will let you treat the captured video stream just like you would a webcam. Job done.
« Last Edit: February 22, 2020, 01:44:17 pm by Ultrapurple »
Online Cat
« Reply #7 on: February 20, 2020, 01:37:44 pm »
The Flir Exx series are recognized as UVC-device, so if a normal UVC webcam works the FLIR should work as well.
At least the desktop version of Skype has no problem with the Flir E60 as video source.
On the Internet, nobody knows you're a cat.
