Author Topic: A High temperature Blackbody - Frasers search and full teardown  (Read 3243 times)
Re: A High temperature Blackbody - Frasers search and full teardown
« Reply #25 on: February 13, 2020, 07:41:14 pm »
No chance of finding a 230VAC heater element, as the controller and SSR will work with 230VAC, so you will probably have to find a 600VA autotransformer to place in the controller case to keep the 115VAC one.
Offline FraserTopic starter
« Reply #26 on: February 13, 2020, 07:56:20 pm »
SeanB,
Ah, but that is not a problem for me.......
A very nice chap gifted me a couple of professional Mikron Blackbodies recently. They are wonderful bits of kit with 19" rack mount controllers and separate Blackbody heads...... they are 115V though. I purchased a really nice 2KW 240V-110V step down transformer. It uses a torroidal transformer and is really compact :) I can power all three of the Blackbodies from that one transformer :) The transformer cost me just £44.
Fraser
« Last Edit: February 13, 2020, 08:08:37 pm by Fraser »
« Reply #27 on: February 17, 2020, 01:43:36 pm »
All of the required parts to return my 1000C blackbody to service have now arrived  :-+
I will be fitting a new power switch, fuseholders and a mini Thermocouple socket to the controller and a new thermocouple and standard thermocouple socket in the head unit.
Note the size of the standard (non-mini) thermocouple connectors ! They are big beasts but the hole in the head unit is sized to take that type of connector as I have already said.
Fraser
