Author Topic: Thermal Imaging Gallery II  (Read 59399 times)
Offline Bill W
    • Fire TICS
Re: Thermal Imaging Gallery II
« Reply #175 on: September 25, 2022, 04:30:09 pm »
OK, so about 4V must be where the micro ADC side settles when open circuit.
The spot units are stand-alone so can be run as a separate 'toy'.  The only oddity is that the ones we bought for Argus2 & Argus3 were narrower field of view ('spot ratio' 20:1) than the commonly sold type which were 10:1.
Bill
The following users thanked this post: Logan
Offline hap2001
« Reply #176 on: January 25, 2023, 10:44:05 am »
Pixel-perfect splash screen for Flir Tau2.
It's 640x512@256 colors BMP, the standard defined by Flir. (Also works on non-640 models)
Including a few test point: analog scan range, resolution, RGB.
I have to zip it because BMP is not allowed to upload.
« Last Edit: February 09, 2023, 10:54:18 am by hap2001 »
Offline gamerpaddy
« Reply #177 on: January 26, 2023, 08:28:47 am »
Subject: Worksite outside my window
Camera: northpoint akir01 (pico384 sensor)
Lens: 19mm f1.0
Original resolution: 384x288
Camera mods: added composite video out jack to connect up a video grabber, stk1160 in this case running on android
Image manipulation: grabber and app greatly reduces image quality, it looks better on the native built in monitor.
edit: made some more today using a different grabber (avermedia ezmaker 7) on a windows tablet
some are blurry, hard to hold it still when its sub zero
warm water exhaust from a toilet paper factory.. probably 500L/s at around 30..40°C, what a waste
looks like this (see attachments)
« Last Edit: January 26, 2023, 10:34:26 am by gamerpaddy »
Offline hap2001
« Reply #178 on: February 05, 2023, 02:25:27 pm »
Seek Shot (Pro/non-pro) 1/2
« Last Edit: February 05, 2023, 02:35:32 pm by hap2001 »
Offline hap2001
« Reply #179 on: February 05, 2023, 02:25:59 pm »
Seek Shot (Pro/non-pro) 2/2
« Last Edit: February 05, 2023, 02:43:38 pm by hap2001 »
Offline gamerpaddy
« Reply #180 on: May 04, 2023, 06:07:17 pm »
p2 pro
i can see my ulis sensor scanning once turned on
& laser pointer stuff
The following users thanked this post: MegaVolt, JOSM
Offline CuriousDude
« Reply #181 on: October 14, 2023, 03:52:10 pm »
Keeping my coffee warm this morning.
« Last Edit: October 15, 2023, 12:44:29 am by CuriousDude »
The following users thanked this post: svgurus
