There no translation is needed practically.
In 95% of cases, you will use only the 1st menu item (resistance measure), and possibly 5% of the 2nd (wire measure) where both screens are without any Chinese characters. 4th (battery saving) and 9th (contrast) you will set only once after buying, and literally 9th is some kind of useless setting because the one acceptable value for contrast is 5 (from the 0-9 range). Then menu items 6th, 7th, and 8th are not even active... assume they are for dev purposes. And finally, the 10th just contains a ton of calibration values.
