Hi and welcome to the forum.
I strongly guess that this is indeed a 510k resistor, you can check it with a meter and thin measure tips.
The chance that it´s defective is low, because of its high resistance.
Follow the path of the input sockets to the chipset, checking the parts in this way.
Hopefully there are somekind of overvoltage protection elements in there, otherwise....
![ThumbsDown :--](https://www.eevblog.com/forum/Smileys/default/icon_thumbsdown.gif)
Good luck!
