I definitely wouldn't expect unprocessed data. They have to maintain the 9hz to make their camera ITAR safe.
Why not? They can simply make toy version hardware eg. with voltage regulators operating temperature 0*C-70*C or use ICs in non MIL versions as well as simplify design and make this thing not usable on battle fields.
For example issue with this thermal gradient detected
Endless posibilities to make this hardware usable only in perfect conditions like room temperature, etc
Probably they had to do it, while reprogramming on board PCB MPU is not a big problem for skilled electronics guys.
Than, not problem what so ever to give someone even low level API while without hardware modyfications they can't get more from this device than it was designed for... maybe like a toy, while they do not provided even temperature scale on LUT map overlay in their app
Sure thing, but I have more to come, double the resolution and frenky's noise reduction.
Still, you have guys black pixels column on the right
Anyway, did you tried to make noise reduction, but using not ONLY one frame but series with some kind of moving average or other methods?
In the case of one image only a little bit of blur to smooth looks nice depending on use case, so one simply need to be able control level of smoothing and this is what I'd like to have in my app, so implemented it.
If one could improove lens in this Seek Thermal camera to be able to do optical magnification of small elements as Mike shown in his first vblog it could be nice.
@Mike - Could you disclosure what external lens you used in your Seek Thermal teradown 1 vbog if this is not a mystery, please?
They very nice fitted on oryginal ones and it looked like easy enhancement DIY to make, but we need proper lens for IR
