Hello and good morning.. Where I teach we have a sds 1102cml+ oscilloscope that does not start and remains with the black screen of the logo. I would appreciate help to repair it, since the warranty date has passed. I have connected through the terminal and this is what appears:
U-Boot SPL 2013.01.01-svn72327 (Jun 02 2021 - 18:19:21)
config ddr_pll_config()++
config ddr_pll_config()--
********am33xx_spl_board_init=720**************
*********mpu_pll=720**************
nand_init+++++
nand_init-----
Lcd_Init()++
SetUpLCD()++
SetUpLCD()--
len=768052, height=480, width=800
Logo from nandflash: base=0x81000000; end=0x810bb81f; end-base=0xbb81f; rwsize=0xbb820; r=0x0
Lcd_Init()--
U-Boot 2013.01.01-svn72327 (Jun 02 2021 - 18:19:21)
I2C: ready
DRAM: 128 MiB
NAND: 256 MiB
MMC: OMAP SD/MMC: 0, OMAP SD/MMC: 1
Using default environment
set_default_env::7914
musb-hdrc: ConfigData=0xde (UTMI-8, dyn FIFOs, bulk combine, bulk split, HB-ISO Rx, HB-ISO Tx, SoftConn)
musb-hdrc: MHDRC RTL version 2.0
musb-hdrc: setup fifo_mode 4
musb-hdrc: 28/31 max ep, 16384/16384 memory
USB Peripheral mode controller at 47401000 using PIO, IRQ 0
USB Host mode controller at 47401800 using PIO, IRQ 0
Net: <ethaddr> not set. Validating first E-fuse MAC
cpsw
Hit any key to stop autoboot
(Re)start USB...
USB0: lowlevel init failed
USB error: all controllers failed lowlevel init
Download Linux from USB to Nandflash...
** Bad device usb 0 **
Booting from nand ...
NAND read: device 0 offset 0x3080000, size 0x300000
3145728 bytes read: OK
## Booting kernel from Legacy Image at 80200000 ...
Image Name: Linux-3.2.0+
Image Type: ARM Linux Kernel Image (uncompressed)
Data Size: 2157768 Bytes = 2.1 MiB
Load Address: 80008000
Entry Point: 80008000
Verifying Checksum ... OK
Loading Kernel Image ... OK
OK
Starting kernel ...
Uncompressing Linux... done, booting the kernel.
init started: BusyBox v1.13.2 (2012-04-08 17:28:57 CDT)
starting pid 519, tty '': '/etc/init.d/rcS'
rS in
Segmentation fault
Segmentation fault
Segmentation fault
Segmentation fault
Segmentation fault
Segmentation fault
/etc/init.d/sysfs.sh: line 17: can't create /proc/sys/kernel/hotplug: nonexistent directory
Segmentation fault
Segmentation fault
/etc/init.d/rcS: line 11: can't create /sys/class/gpio/export: nonexistent directory
/etc/init.d/rcS: line 12: can't create /sys/class/gpio/gpio113/direction: nonexistent directory
/etc/init.d/rcS: line 13: can't create /sys/class/gpio/gpio113/value: nonexistent directory
/etc/init.d/rcS: line 15: setterm: not found
/etc/init.d/rcS: line 18: can't open /dev/null
can't open /dev/ttyO0: No such file or directory
/etc/init.d/rcS: line 24: can't open /dev/null
/etc/init.d/rcS: line 21: can't open /dev/null
process '-/bin/sh' (pid 533) exited. Scheduling for restart.
process '-/bin/sh' (pid 534) exited. Scheduling for restart.
process '-/bin/sh' (pid 535) exited. Scheduling for restart.
Thanks for the help!
Tautech , Thank you so much for the help! The oscilloscope has come back to life!! Awesome!
