Should have read the thread before I opened my mouth. Found the Siglent America site from one of the previous posts so was able to download the manual. Thanks. As to my problem of clearing the screen and then grabbing another signal I found that having the trigger set correctly solves a lot of problems. With the trigger set you just have to press the run/stop button to clear the screen and then the new signal triggers when you turn the red light out.Hope to get that 10th review soon so drawing 4 can proceed.
Just saw the message and can't believe I won. No email or anything yet from Siglent so I don't know what I need to do next but I will be asking for the Signal Generator as I love my SDS 1052DL and don't need anything more powerful or with more features. The signal generator will be a great addition to my equipment.
errr ... any new video to show bugs are solved?
Quote from: 3roomlab on March 11, 2015, 02:34:21 amerrr ... any new video to show bugs are solved? which product?
Just received my Free Siglent Generator today. Looks very nice and it's very easy to use. Controls are all very intuitive and easy to navigate. Only one question, and I will search the Siglent Tech Thread and the SDG1000 thread for some help. When I turn the generator on it asks you to select a language. I select English and then I go into the "Utility"- "System" menu and select English and then select "Last Configuration" on startup. I also set up the way it displays numbers in this menu. When I turn the generator off and then back on it again asks me to select a language. It has remembered how to display numbers but has not remembered the language selection. I am probably just not doing something right so will search the other threads for an answer. Firmware is the latest from Siglent. Other than this minor annoyance I am thrilled with the generator so far.
Maybe it is a new feature of the firmware. Some other equipment from other manufacturers does that as well.edit: I just installed the latest firmware on my SDG1010 and it asks for the language at power on indeed.
Quote from: jobog on March 10, 2015, 10:30:31 pmJust saw the message and can't believe I won. No email or anything yet from Siglent so I don't know what I need to do next but I will be asking for the Signal Generator as I love my SDS 1052DL and don't need anything more powerful or with more features. The signal generator will be a great addition to my equipment.Received the email from Siglent and will opt for the Signal Generator. This is a great promotion effort by Siglent and I hope they continue so that others may find themselves the lucky winner.Thank you Siglent and I will enjoy using my Signal Generator.
Quote from: nctnico on March 17, 2015, 01:29:50 amMaybe it is a new feature of the firmware. Some other equipment from other manufacturers does that as well.edit: I just installed the latest firmware on my SDG1010 and it asks for the language at power on indeed.I for one do not support this feature, it has caused much confusion and frustration to many Siglent owners. Yes any button push after startup will step past the language screen.At one time it was displayed for x number of starts only, even that was frustrating.Siglent, just make it clear how to change the language in the manual and leave it at that. BTWCongrats jobog
