Author Topic: Why would modern digital scopes only offer 2.5kpts memory depth?  (Read 16020 times)
Offline EcklarTopic starter
  • Hobbyist
Why do I still see numerous digital oscilloscopes
that cost more that $ 1000 US only offer
2.5kpts memory depth?   Yeah, Tektronix
Is one that comes to mind.  When the Chinese easily
offer 1,000,000 depth on scopes that cost
less that $ 400 and you can easily get 14M points
On Rigol for a little more.
Memory must be one of the cheapest components
of a system today.  To the point where it's simply a commodity.
And since the 2.5K scopes
already have memory in place then the software
and system is set up for it.  Is there some
disadvantage to having greater memory depth
or is there some workaround so you can
So the same job without it?
Why wouldn't Tektronix just add loads of memory
without increasing costs and then address
the market.   Please don't tell me they're
stupid…. Since I'd like to get the reasoning.
Offline Howardlong
Re: Why would modern digital scopes only offer 2.5kpts memory depth?
« Reply #1 on: January 16, 2015, 08:05:34 pm »
I strongly suspect there are tens of thousands of these scopes used in universities across the world who have coursework attached to them.
So whether it's natural attrition from studes blowing them up or just lecturers being too lazy to update the course work, there is still a market for these scopes.
I still have one, it's been very good to me, but yes, I have better spec'd units too now.
Offline mikeselectricstuff
    • Mike's Electric Stuff
« Reply #2 on: January 16, 2015, 08:19:36 pm »
The Teks aren't "modern"  - they are archaic designs that Danaher are tyring to squeeze the last drop out of whilst the competition have been pissing all over them at the low end for years.
If they didn't have the Tek name they'd have been toast long ago.
Day Job: Mostly LEDs
Offline jadew
« Reply #3 on: January 16, 2015, 08:22:02 pm »
Was about to say the same thing but you beat me to it.
They don't care about the low end market so they don't put any effort in updating these outdated designs, they will eventually stop selling - if they didn't stop already.
Offline electr_peter
  • Country: lt
« Reply #4 on: January 16, 2015, 08:25:36 pm »
Because they are not modern in a real sense.
« Reply #5 on: January 16, 2015, 08:39:15 pm »
Though I wonder how many scops Rigol has to sell to make the same profit as Tek make when some mug buys a TBS series...
Offline pickle9000
« Reply #6 on: January 16, 2015, 08:49:52 pm »
Tequipment  said in one post 200pcs ds1054z coming in just after the new year (regular order size?). They are consistently sold out and about 3 weeks between restocking. No idea on the margin on these but if they can get them into the educational market they will make a killing in a few years.
Offline nowlan
« Reply #7 on: January 17, 2015, 02:11:09 am »
Is the 2.5k not tied to their fpga ram?
Online EEVblog
« Reply #8 on: January 17, 2015, 05:29:39 am »
They are not modern, they are based on 20yo architecture.
That "Danaher Way" is to extract every last cent out of every product until it can milk no more.
Offline devanno
  • Old newbie
« Reply #9 on: January 17, 2015, 06:00:54 am »
In addition to the comments about the logical age of the Tek o'scopes, etc. The more memory you have, the more processor cycles it takes to keep it refreshed.  Older designs may just not have the bus nor bandwidth in the processor to update and process all those memory points.    Look at what happens to your sample rate as you increase memory depth, and you'll see what I mean.
Free Electrons - Just one, please.
Offline Howardlong
« Reply #10 on: January 17, 2015, 02:30:05 pm »
I do wonder how much Tek, Agilent, LeCroy etc actually care about a segment of the market that's under $2,000, and why should they?
In real terms accessiblity to an oscilloscope has never been so good. I know that there was no way I could justify purchasing a new scope 20 years ago at that time in my career or bearing in mind how much they cost in real terms back then. Blimey, I remember buying my own TDS2024 ten years ago for £1,800, that hurt.
Offline coppice
« Reply #11 on: January 17, 2015, 02:34:27 pm »
Its often a requirement from their customer, especially defence customers. "Parts must be available for XXX years" is a common requirement in big supply contracts, but "Further new units must be available for XXX years" is also a common requirement. They want to be able to get people used to one model, and have it ingrained in their manuals.
Offline coppice
« Reply #12 on: January 17, 2015, 02:38:03 pm »
Volume. The high end of their range is the one they are always questioning. They rarely produce the most extreme product that they could, because the volume would be so low they'd never be able to set a realistic price that would let recover their NRE.
Offline MarkL
« Reply #13 on: January 17, 2015, 03:17:45 pm »
Like the TDS3000 series with its 10k pts, I believe the TDS2000 with 2.5k pts uses the same technology, but is reduced in size for cost saving.
They use a technology called "Fast In Slow Out" (FISO) which uses a CCD to gather analog data at high speed and then digitizes it during a slower read-out phase after the acquisition is complete.  So there is no FPGA or high speed acquisition RAM like you would find on a modern scope.  The CCD is also what gives these scopes more noise and significant warm-up drift.
EDN article with a little more detail:
  http://www.edn.com/electronics-products/other/4316014/Popularly-priced-DSOs-aim-to-outsell-market-leader
Tek has a some patents on the technology dating from the mid 90's: 5,321,656 and 5,200,983 and  I'm sure there are others.
A breakthrough 20 years ago.  But really.  It needs to go away now.
The following users thanked this post: zbqpig
Offline Pjotr
« Reply #14 on: January 17, 2015, 03:51:36 pm »
Duh... ??? Not with Tek. I was planning a new lab set up and new scopemeters for the service department in the beginning of 2000. Invited Tek to what they had to offer and asked for after life support. There wasn't anything at all! When the product goes out of production, servicing by Tek stopped as well  :-[ That alone was reason to leave Tek for what it was and moved to Fluke.
Offline coppice
« Reply #15 on: January 17, 2015, 04:06:24 pm »
You just weren't significant enough to get their attention. Buy a lot of one model and they will keep it available, either just for you or for everyone. Governments are usually the only buyers big enough to get this kind of treatment.
Offline Pjotr
« Reply #16 on: January 17, 2015, 04:18:14 pm »
Yes, modern times with old performance and price tags  :clap:
Offline Wuerstchenhund
  • Able to drop by occasionally only
« Reply #17 on: January 17, 2015, 07:33:38 pm »
Oh, they do. For Agilent Keysight the entry level is very important, they make good money not because the profit per scope is high but because of the numbers they shift. These scopes are also used as a vehicle to bring the name (which recently changed for a second time) out there (a problem that Tek doesn't have to the same extend), and if Keysight scopes are almost omni-present including in schools then chances are that they will be the vendor to go for new purchases.
LeCroy has had entry level scopes since the late 90's.  LeCroy also saw them as a vehicle to get their name out more, but (unlike Agilent/Keysight) LeCroy never considered the low end market relevant enough to justify more serious investments. Therefore all their entry level scopes were (and still are) simple rebadge jobs. Their first one (LightRunner LP) was an Iwatsu rebadge, as was the later WaveJet 300/300A Series. Because these scopes are pretty expensive, in around 2009 LeCroy decided to also rebadge some Siglent low end scopes (sold as 'WaveAce'). While the Iwatsu rebadges were good although basic and very expensive scopes, the Siglent rebadge didn't go down that well as these scopes suffered from very embarrassing firmware problems of which many never were fixed (typical Siglent), and lead to quite a few angry customers.
Tek, well, they know that they do still have a very big advantage which is their name (HP was well known but with two subsequent name changes getting their name 'stuck' is more difficult, and LeCroy is really only a name for high end scopes), and for the last ten years or so they're milking this advantage out by flogging off outdated designs, which as Dave says is typical for a Danaher company. The only problem for Tek is that the later generation of EE's hasn't grown up with the fond memory of Tek's glory days of yesteryear, so they have to convince with their products (which at least for scopes are overwhelmingly rather poor).
Indeed. And thanks to high integration and cheap processing you get quite a lot even in a typical entry level scope like the DS1000z these days.
« Last Edit: January 17, 2015, 08:04:19 pm by Wuerstchenhund »
Offline edavid
« Reply #18 on: January 17, 2015, 08:09:26 pm »
That article is just Agilent FUD.  Has Tektronix ever said that they still use a FISO architecture?  Who would they get to fab the chips?  No one has a non-sensor CCD process any more.
Offline coppice
« Reply #19 on: January 17, 2015, 08:13:11 pm »
People keep saying that, but isn't LeCroy still a major owner of Iwatsu? These things seem more like actual LeCroy products.
« Reply #20 on: January 17, 2015, 09:11:16 pm »
LeCroy was never an owner of Iwatsu. They once invested a large sum when LeCroy choose them to produce the WaveRunner(2) LT and WavePro 900 Series (both built by Iwatsu but designed by LeCroy). They also allowed Iwatsu to sell the WaveRunner(2) LT as Iwatsu scope in Japan while LeCroy sold it as their own in the rest of the world (a similar deal is now going on with Siglent and the SDS3000 aka WaveSurfer 3000).
LiteRunner and WaveJet are designed by Iwatsu, not by LeCroy. The firmware is also made by Iwatsu. This also shows in the general scope layout and the menu structure, which is clearly different from LeCroy-designed scopes (which, for example, all have the horizontal controls on the left, not on the right).
The Iwatsu partnership still continues, although for one scope in the entry level only (the 'new' WaveJet 300T is another Iwatsu rebadge). For mid-range and high-end it stopped with the introduction of the X-Stream scopes (WaveMaster 8000, WavePro 7000, WaveRunner 6000, which came out between 2001 and 2003).
« Last Edit: January 17, 2015, 09:14:48 pm by Wuerstchenhund »
Offline wreeve
    • embedded u systems limited
« Reply #21 on: January 17, 2015, 09:50:40 pm »
To be fair to Tektronix....I don't see a "Tektronix jitter problem / ac couple problem" thread on here!
Offline MarkL
« Reply #22 on: January 18, 2015, 11:22:51 pm »
If you like, here's another article that's less fuddy:
  http://www.edn.com/electronics-news/4362126/Leading-Edge-4362126
But, point taken that there's no explicit information what Tek is using today.
I would think, however, Tek didn't invest the resources to re-architect the entire acquisition portion of their ASIC in these TDS models, such as in their jumps from plain to B to C version in the TDS3k.  If they did they would at least give it more memory.  The acquisition specs for these units have been unchanged for the last 20 years.  Another clue is that they all lack high resolution (boxcar averaging) which is another feature that can't be done with their CCD architecture.
What is it about a non-sensor CCD process that a contract fab couldn't do for Tek?
Offline edavid
« Reply #23 on: January 18, 2015, 11:35:10 pm »
There aren't really contract fabs, only foundries.  A foundry wouldn't develop a new CCD process (or any process) just for Tek, because it wouldn't be cost effective.  It would be much cheaper to design a flash ADC + SRAM front end in a normal logic process.
Online EEVblog
« Reply #24 on: January 19, 2015, 12:04:15 am »
If they aren't then there is absolutely no reason to have the exact same 2.5KB memory as used 20 years ago.
Rumor has it have have huge stockpiles of those old chips.
