When you use an multimeter to measure the threshold voltage of a diode, the multimeter sends a small current through the diode and measures the Voltage across it. Correct me if I'm wrong.
Are there any standards how big this current should be? On the most modern DMMs it's seems to be 1mA. Is it always so?
