Author Topic: [thread closed]why TestController software can not find my GPP-4323 power supply  (Read 789 times)
Offline ali_asadzadehTopic starter
My GPP-4323 has no Ethernet option, only USB and RS232, I have connected it with USB to my PC, and I can Detect it with a normal terminal program, like bray terminal, But Test Controller software can not detect and find it, what am I doing wrong?
I can detect and send commands to GPP-4323 with a normal termianl program
The load devices tab of Test controller and it's config, (and yes I have disconnected the bray terminal before testing with Test controller software)
If I check scan serial ports, It would only find COM3 which is another Serial port on my PC motherboard and it would not find COM4 which is the actual GPP-4323 port
« Last Edit: April 17, 2023, 07:48:39 am by ali_asadzadeh »
ASiDesigner, Stands for Application specific intelligent devices
I'm a Digital Expert from 8-bits to 64-bits
Offline coromonadalix
Re: why TestController software can not find my GPP-4323 power supply?
« Reply #1 on: April 16, 2023, 02:49:08 pm »
you should have posted in the software thread instead of starting a new thread   ....
« Reply #2 on: April 16, 2023, 03:24:20 pm »
How can I move it there?
« Reply #3 on: April 16, 2023, 04:06:02 pm »
ask some moderators
you have a report fuction on the threads ...
Offline tautech
« Reply #4 on: April 16, 2023, 07:11:50 pm »
You can't.
All things TC are here:
https://www.eevblog.com/forum/testgear/program-that-can-log-from-many-multimeters/
What you can do is Copy/Paste your questions to HKJ into that thread and add a 'thread closed message here and maybe add a link to your TC post should others land here with the same question in years to come.
You can also change/edit the topic name if you please.
I have copy and past the message in this link
https://www.eevblog.com/forum/testgear/program-that-can-log-from-many-multimeters/msg4817441/#msg4817441
And modify the  title with [thread closed]
