I don’t know who ab-precision is, but the original article made by Stäubli (formerly Multi-Contact), part numbers in tggzzz’s post above, are excellent.
In addition to the benefits that tggzzz listed and mawyatt confirmed, they also have the unique ability to be mated plug-to-plug on the male side, since you can just shove one plug into the other, and still use the stacking jacks on the backs. Their light weight also makes them ideal for test leads made of thin wire, so that there isn’t a heavy plug dangling off a thin lead. I used them to make banana-to-DuPont cables, for example. The way that their spring force works makes them fit snugly in basically any jack, yet without being annoyingly hard to use in tight jacks.
The downsides are that they only make solder versions of them, and just as mawyatt said, they can snag when inserting them into certain jacks, so careful alignment is sometimes necessary.
But perhaps their resistance/voltage-drop are higher than other jacks?
Their maximum current is not as high as the highest-current ones from Stäubli and Hirschmann, but still excellent, as tggzzz said.
Their very large contact area, and the fact that the contact itself is quite small (so even if the resistivity is higher, the total resistance is not) means the overall resistance is still very low.
The wall/tube seems thin and it's likely made of relatively low-conducting-metal, because it need to have a spring-property, unless they are made of a special copper-alloy-mix?
Beryllium copper according to Stäubli. (Good to know, should I ever need to file one down!) So definitely
not a low-conductivity metal. (That is a weird assumption to make for a top-quality electrical connector.)
Or will the gold-plating compensate for that?
Gold is not used as contact plating for its conductivity — copper and silver are much better — but for its resistance to corrosion.
