This is the best
Nope. (Not that one can really call one style the “best” anyway, since it also depends on what you’re mating it with.)
Those Pomona-style ones are short, and won’t mate with certain recessed banana plugs that expect the longer “European style” banana plugs. And they’re rated for 15A, while some from Stäubli and Hirschmann (of the lantern style shown in the very first image) can handle 32A.
The best I mean,The banana plug and the shrapnel are integrated, so there is no possibility of poor contact.
The author of the first post said that the banana plug has a problem with excessive current and is prone to heat, causing the copper shrapnel to lose its elasticity.
True, there are no additional interfaces, but that style doesn’t make as much contact in total as the lantern style.
(Also I only assume you’re using machine translation, because “shrapnel” is completely nonsensical in English for any part of a connector.)
Ummm… no they did not. They said nothing of the sort. Someone in a
reply said they had ”bad connections” (without specifying them) with
cheap versions of the lantern-style plugs.
High quality lantern-style plugs do not have that problem, and the lantern style contact is used in high-reliability connectors of all shapes and sizes precisely because it provides some of the best performance of any contact shape. It just needs to be manufactured competently.
(I have thrown out cheap versions of the Pomona style ones you like. They were made of cheap metal that deformed after a single insertion, making them useless. I do use real Pomona-branded ones of those, among others.)
