Author Topic: Why does everyone have twenty oscilliscopes?  (Read 88200 times)
Offline rrinker
Re: Why does everyone have twenty oscilliscopes?
« Reply #225 on: January 29, 2016, 04:06:34 am »
^ +1  That and the matching signal generator are works of art, not mere electronics.
I feel so inadequate after reading this thread, 1 scope and 2 multimeters (not counting the half dozen free HF ones I use on model railroad stuff).
I keep looking for a decent 20MHz or so Tek analog scope for a decent price, mostly just to have a quality analog scope.
Offline bitseeker
« Reply #226 on: January 29, 2016, 04:13:36 am »
It's OK, rrinker. I only have two scopes, an analog and a digital, and the analog one needs work. So, effectively, I have one.
On the other hand, I have 11 multimeters at the moment. Oy! Gotta start a separate thread. :-DMM
Offline rrinker
« Reply #227 on: January 29, 2016, 04:18:44 am »
 I suppose it is some consolation that I am considering purchasing another multimeter....
Offline pickle9000
« Reply #228 on: January 29, 2016, 04:23:06 am »
I only have seven.
Offline billfernandez
« Reply #229 on: January 29, 2016, 04:35:38 am »
20 oscilloscopes?  Well you see I can't afford a really high end scope, so I figure that I can simulate one with a bunch of cheap scopes.
I find that if I hook up my twenty 50MHz scopes in parallel that I can divide the incoming signal among them for an effective aggregate bandwidth of 1GHZ.  And since some of them are two-channel and some are four-channel scopes, if I hook them all in parallel I can get an aggregate bandwidth of more than 2.4GHz which is enough to troubleshoot WiFi routers and microwave ovens.
Or if I hook all the inputs in series I can either use them to handle higher input voltages, such as those generated by my Tesla coil, or get ultra-high resolution on very weak signals.  Why I can even peer into the nanovolt signal range to monitor the heartbeats of amoebas under my microscope.  Pretty cool!
Of course it's kind of awkward having a waveform split across all those displays, but sometimes you just gotta do with what you can afford.  Amirite?
« Last Edit: January 31, 2016, 03:42:00 pm by billfernandez »
Offline bitseeker
« Reply #230 on: January 29, 2016, 05:22:11 am »
Bill, you forgot to set them up in a grid for more visual real estate.
Offline Berni
  • Country: si
« Reply #231 on: January 29, 2016, 10:24:13 am »
Of course it's kind of awkward having a waveform split across all those displays, but sometimes you just gotta do with with you can afford.  Amirite?
 :-DD
But really that's pretty much how the 100GHz scope from LeCroy works. Its 4 really fast scopes put together, each one of them built from 4 interleaved ADCs that are in itself built from interleaved ADC blocks internally.
Offline Addicted2AnalogTek
« Reply #232 on: February 12, 2016, 12:02:19 am »
Well I don't quite have 20... yet.   I do have 9 Teks and also intend to add a Rigol DS1054Z within the next two weeks.  There's also a possibility that I will be getting my hands on a Tek 561A.
Inventory:
(1) Tek 454A
(2) Tek 465
(2) Tek 468
(3) Tek 485
(1) Tek 7613
Offline artag
« Reply #233 on: February 12, 2016, 12:17:54 am »
Don't worry. Once you've got one, the next few come along to join them. Pretty soon you're wondering if you should stop (no, of course you shouldn't).
Offline uncle_bob
« Reply #234 on: February 12, 2016, 12:28:02 am »
Inventory:
(1) Tek 454A
(2) Tek 465
(2) Tek 468
(3) Tek 485
(1) Tek 7613
Hi
I didn't realize we had to be able to *count* them all .... yikes ...
465's at least two
475's at least two
2465's more than four
2465A's more than four
2467B's at lest three working, about a dozen total.
7xxx series, had a dozen or so, sold them to a kid for next to nothing
probably another 5 or 10 that I'm unable to spot
Do we have to count the digital scopes as well? This is getting tiring ....
Bob (heading back to my beer)
« Reply #235 on: February 12, 2016, 01:27:54 am »
Cheezus, Bob!   Sell me a 2467B !! haha
Offline rrinker
« Reply #236 on: February 12, 2016, 04:01:39 am »
 Me too!  haha out of the 9 non-working there has to be enough parts to get 2 or 3 working ones!
 :-DD
Offline CustomEngineerer
« Reply #237 on: February 12, 2016, 04:07:59 am »
Have you considered hooking them up anti-parallel?
Offline rrinker
« Reply #238 on: February 12, 2016, 04:23:23 am »
That would just result in one giant flat line across all the displays as the waveforms all cancel each other out.
Offline pickle9000
« Reply #239 on: February 12, 2016, 04:47:18 am »
If I had 20 scopes I'd be very tempted to so something like this.
And then I would would be drawn and quartered.
Offline pickle9000
« Reply #240 on: February 12, 2016, 04:52:24 am »
As a quick followup.
Anyone with 20 scopes, video camera, youtube account and enough room to do some oscilloscope dominoes?
The following users thanked this post: Electro Detective
Offline tautech
« Reply #241 on: February 12, 2016, 06:31:56 am »
That's just sick.  :scared:
Offline pickle9000
« Reply #242 on: February 12, 2016, 07:12:42 am »
In my defense, they would not be my oscilloscopes, so I can enjoy the event without risk. I can't ask Dave because it could be career ending.
It would work with multimeters (dominoes) but there is no real danger there.
Take a new Fluke DMM and and a new Rigol ds1054z drop off a roof. Set up a poll, the lowest count item get's to live. Will it be the Fluke or the Rigol? If it's a tie they both go.
Offline Berni
  • Country: si
« Reply #243 on: February 12, 2016, 07:30:01 am »
Then just drop the fluke since it would just bounce anyway.
Offline Keysight DanielBogdanoff
  • ALL THE SCOPES!
    • Keysight Scopes YouTube channel
« Reply #244 on: February 12, 2016, 06:50:52 pm »
Don't tempt us.
  • ALL THE SCOPES!
« Reply #245 on: February 12, 2016, 06:52:15 pm »
And before you ask for one, register to win one at www.scopemonth.com
If you win this, you won't need your other 19.
Offline uncle_bob
« Reply #246 on: February 12, 2016, 11:25:20 pm »
Hi
I registered. One can *never* have to many scopes !!!
Bob
Offline bills
« Reply #247 on: February 12, 2016, 11:29:27 pm »
As I said it is because we can.
Never argue with idiots. They drag you down to their level and beat you with experience.
Offline bitseeker
« Reply #248 on: February 13, 2016, 07:13:22 am »
Hi
Bob
Especially when one (this one) is nowhere near 20, yet.  ;D Also registered.
(Of course, Daniel, anytime you need more space, I'm happy to adopt a scope or three.)
Offline elex_enthusiast
  • Country: ph
  • Everything has user-salvageable parts inside!!!!
« Reply #249 on: February 13, 2016, 10:37:53 am »
Don't tempt us.
WOW!!! :o Now there are more than just 20 counts.. :-+
Always learn how to break and fix things electronics!
