hello,
I have this steamer, it claims to work at
120V and at Power 1700W
which comes to 15Amperes
I bought clamp meter to verify the claimed power at 110V, how can I use this clamp meter to measure this machine while running?
WIll clamp meter work on cable wire which has 3 wires in it, hot, neutral and ground or the clamp meter needs only one wire to measure amps? if it needs only one wire then how am I supposed to get one wire out of this machine cable?
I have other devices to measures AC current consumption but I am running into same problem about how to measure Amps on cable running 3 wires ( hot neutral ground )
MACHINE
CLAMP METER i have with me
