Author Topic: MSO5000 Jitter and Eye Diagrams  (Read 2364 times)
Offline sorenkirTopic starter
« on: October 07, 2022, 09:40:57 am »
Hello,
Just for fun, I have tried the Jitter analysis feature of my MSO5074 (upgraded to 350MHz BW with all options ;-)).
I have managed to do consistent measurements of jittery clocks and signals generated with a Wandel&Goltermann Transmission Jitter Analyzer SF-60.
10Mbit/s signal with 0.30UI 10kHz TIE jitter:
100Mbit/s signal with 0.40UI 10kHz TIE jitter:
1Mbit/s signal with 0.40UI 100Hz TIE jitter:
Then I wanted to try the Eye Diagram feature, but no matter what I tried in the settings (triggering, eye settings, timebase), I did not manage to get any results.
The scope is displaying "Eye analyzing..." but the measure window is not updated, color persistance is not working.
Has anyone managed to achieve anything with this feature ?
Thanks,
Michel.
« Last Edit: October 07, 2022, 09:42:57 am by sorenkir »
Offline tv84
  • Country: pt
Re: MSO5000 Jitter and Eye Diagrams
« Reply #1 on: October 07, 2022, 01:44:36 pm »
« Reply #2 on: October 08, 2022, 10:47:03 am »
Thanks for the link.
I don't know how you did setup the scope. The histogram seems to have been set manually ?
Anyhow, I don't see any Eye measurement: your measure window is filled with *
Michel.
Offline trampas
« Reply #3 on: November 15, 2022, 12:06:13 am »
I was trying the jitter measurement on my hacked MSO5074 with firmware 1.03.00.03 and the jitter measurement does not seem to work.  Does anyone know why it would not work?   All the buttons work but nothing shows up in the measurement.
Never mind I figured it out.  Apparently you need to zoom way out on the waveform for the jitter measurement to work.
« Last Edit: November 15, 2022, 12:09:02 am by trampas »
« Reply #4 on: November 15, 2022, 01:50:59 pm »
You are right.
I think it needs enough data to perform measurement (in that case only, the message "Jitter analyzing..." is displayed)
Michel.
Offline androm
« Reply #5 on: July 24, 2023, 10:30:48 am »
Hi !
Can you share which files did you use for the hack to get the jitter and eye analysis ? (actually, i have the MSO 5074)
Thanks.
Offline Sighound36
« Reply #6 on: July 24, 2023, 12:01:14 pm »
Tv84 & myself achived this some 4 years ago, however I wouldn't say it's particularly accurate imho
Just followed the link, yep that's the one we couldn't get it happen on the MSO7000 correctly what ever we tried. Like the RSA3 to 5065 its a hardware issue imho
« Last Edit: July 24, 2023, 02:21:57 pm by Sighound36 »
The following users thanked this post: androm
Offline CosteC
« Reply #7 on: August 12, 2024, 06:06:42 pm »
I managed to get Jitter measurement working, key is many, many cycles on screen to be visible. I am however still not sure how exactly clock recovery works...
But totally zero lack on Eye Diagram. Did anybody made it work? Any case, even basic, using build in generator?
