I recently got a free, beat-up, and dead-ish 117 meter. Knowing that it uses the same board as the 110plus/114/115/116 I picked up a cheap working 110plus for comparison (I read on eevblog that the 110plus is a 114 rebadged for Lowes).
After seeing a cool post by Excavatoree about his Fluke 10 (link below) and being aware of other similar Fluke trickiness I wondered if the Hz, Diode, and Cap functions might work on the 110.
The 110 dial won't rotate past continuity so I put the 110 board into the 117 top case and indeed the Diode/Cap setting works! I haven't yet modified the 110 to allow the extra rotation but I've attached photos of the two so you can see the stops.
Sadly, the Hz setting does not work - the yellow button responds only with an irritated beep. On volt alert or current settings the meter displays ---- as could be expected.
I've attached some other photos of the internals showing the differences...
here's Excavatoree's post about modding his Fluke 10: https://www.eevblog.com/forum/chat/fluke-25-my-first-digital-multimeter/msg36115/#msg36115
