Author Topic: Which dso current clamp to buy?  (Read 2430 times)
Offline ChrissTopic starter
« on: December 14, 2019, 07:44:53 am »
Hi!
I need a cheap current clamp for my job and dso.
Nothing accurate but more to see does the current is around the spec or not.
Mostly used on car starter motor, car charging circuit and for checking of engine relative compression.
I found these two clamps which are interesting to me:
1. Hantek CC-650
2. HoldPeak HP-605A which is actually the same as BTmeter BT-605A I assume.
Does somebody have some experience with these tool's?
Are they worth the money and could meet my requirement?
Or maybe an advice for another company but also cheap one?
Thank you.
My best regards.
Offline hfleming
  • Country: no
Re: Which dso current clamp to buy?
« Reply #1 on: December 14, 2019, 03:07:07 pm »
Picotech also has a range of current clamp probes :
https://www.picotech.com/accessories/current-probes-clamps
I have their TA167 200/2000A probe and am very happy with it.
« Reply #2 on: December 14, 2019, 03:30:15 pm »
Thanks for reply.
It is a bit out of my budget.
I'm thinking to buy something up to $60- $70.
When I saw that cheap BT clamp and compared to the Hantek technically of course I'm curios does the Hantek really worth the money?
Is it a similar hardware like the BT?
As I had bad experiences with Hantek product and support I don't trust them anymore.
If somebody have any experience with my 2 mentioned tools I would really appreciate that.
Thanks
Offline myf
« Reply #3 on: December 14, 2019, 05:14:01 pm »
Hello,
There is also the hantek "CC-65 AC-DC" at about $60 on amazon.fr
This page https://fr.aliexpress.com/item/33000093926.html compares these two clamps.
I already have a ut-210e clamp, but I can't log its measures.
Have a nice day !
F. from France.
Offline nctnico
« Reply #4 on: December 14, 2019, 06:04:03 pm »
Thanks for reply.
In this price range you can't expect any support or warranty. So either pay a little and throw the device away if it turns out to be a dud or spend big bucks.
« Reply #5 on: December 14, 2019, 08:04:55 pm »
Does somebody have the tool's I prefere?
Maybe looked inside?  Just to see how it is built?
Thanks.
Offline threephase
« Reply #6 on: December 15, 2019, 10:46:13 am »
There is a video on YouTube on the use of the CC-650
https://youtu.be/FfaY5ej1TOk
and a teardown of the smaller CC-65
https://youtu.be/gghixxu_NC8
They may answer some of your questions.
Kind regards
« Reply #7 on: December 15, 2019, 11:27:07 am »
Thank you very much.
Offline DaneLaw
« Reply #8 on: November 25, 2020, 02:23:59 am »
Checking the forums for feedback and this thread pops up,
OP, if you still in the market for these el-cheapo DSO current clamps.?
Just been down that road myself to use with my relative new DSO I got in the start of the year, and acquired 3 of these cheap current clamps, here over the last ½ year, They cost around 100 bucks in total, delivered.
All cheapos from China
Hantek CC65 /20khz / sub60A /38USD
ETCR007AD /100khz / sub60A /50USD
HoldPeak 605A /?? / sub600A /15USD
https://i.imgur.com/ZpmJqux.mp4
The HantekCC65 got the cleanest waveform and easiest to trigger on
ETCR007AD got a +/- wheel on the side where you can align.. the Hantek got a degauss button, the 605A its align feature seems to be, focused on a DMM Holdpeak + other brands' often are promoting alongside 605A... also no variable-switch for different values/sensitivity.. recall its 1mv to 1A. and you need some wattage-potency behind the signal, so not good for low current  (600A unit).
here a test with a toaster HoldPeak 605A.
https://i.imgur.com/yUrAeXz.mp4
Here the Hantek CC65 below and the ETCR007AD on top.(the load is just an RGB LED USBlight changing colors, sub300mA)
The Hantek CC65 is a lot cleaner, actually first thougth the ETCR007AD was faulty, sadly it looks like its the norm with this unit
https://i.imgur.com/Cj2B5AJ.mp4
Will try to test them with an 18usd spot welder, and see if they can grasp that current waveform reliably.
https://i.imgur.com/Nb84KkR.jpg
https://i.imgur.com/h9Vj9Qf.jpg
https://i.imgur.com/fY2kR6g.jpg
« Last Edit: November 25, 2020, 02:50:21 am by DaneLaw »
Online ADT123
    • Pico Technology
« Reply #9 on: November 25, 2020, 05:29:22 am »
For the relative compression and charging circuit applications you mention 600A range should be OK.  For starter motors however its fairly common to see >1000A peak at the start.
Smaller capacity low compression engines when warm will usually be below 600A but if an engine is cold or high compression (most diesel engines) or large capacity then a 2000A clamp will be better.
Disclaimer: I have worked for Pico Technology for over 30 years and designed some of their early oscilloscopes.
We are always recruiting talented hardware and software engineers! Happy to answer Pico related questions when time permits but here as electronics is a hobby
