Dave or No Dave i purchased a GDS-3352, the only scope that offers 350MHz 5GSa/s 75ohm, with low ppm under $10Kusd.
The "Low Memory" 25k points and the Medium range wfm/s "85x better than Owon Top of the Line", were enough for me, considering the price i payd, shure, if i had $17.OOOusd. i would have bought LeCroy WaveSurfer 104MXs-B 1GHz 4ch 10GSa/s, 32 Mpts Interleaved, 22.000wfm/s, 10" Touch Screen.
not even a fully maxed out Agilent DSOX3K
problem with Agilent DSOX3K is the 4 GSa/s & the 2MPoints Memory, or 5GSa/s & 4Mpts in the 1GHz version, 2ch $9,965 4ch $13,020usd.
at 5GSa/s anything less than 10MPoints is not enough.
and i hate the software frequency counter.
DSOX3032A similar scope is $6,521usd. 2ch 350MHz 4GSa/s.
i was looking for 5GSa/s minium with as High BW as i could get with as low ppm as my wallet allowed.
DSOX2022A is limited to 200MHz, and 2GSa/s, with 100 kpts $2,215, yes it has more wfm/s but thats not all.
Tektronix DPO4034B 350 MHz 4-channel Digital Phosphor Oscilloscope is $10,700usd. limited to 2.5GSa/s.
WAVESURFER 42MXS-B $9,990usd.
WAVESURFER 44MXS-B $10,400usd.
less than ideal memory is tolerable, low wfm/s is bad, low BW is worse, and low GSa/s is useless.
in this price range there is always a sacrifice,
for me the Instek GDS-3352 had the balance between the performance vs. price i needed.
shure some people need more the 1M wfm/s of the Agilent 3K for glitch detection,
or the Big memory of the Tektronix DPO4K & Rigol DS4K
Rigol DS4032 $3899usd. is limited to 4GSa/s,
Rigol DS6062 $5600usd, 5GSa/s has 3points at 600MHz, single ch, or 1.5pts both ch, 600ps rise times/200ps per division.
Rigol DS6102 $7500usd, at 5GSa/s has 2 points at 1GHz, single ch, or 1pt both, 400ps rise times.
at that speed 5GSa/s is not enough.
