After putting the YIG oscillator and filter back in, I started to see of the step attenuator at the input is working properly. Removed the rigid SMA cables from the input and output of the 0 - 70 dB attenuator, and connected my signal generator to the input and the scope to the output.
The attenuator's control port was still attached to the SA, so I was able to change the attenuation using the SA's control menus. Applied 20 MHz, 0 dBm test signal to the input, and at 10 dB attenuation was expecting to see - 10 dBm at the output, but saw much, much less than that. In the end, it came out that one of the 20 dB segments in the attenuator is stuck, so the attenuator seems to be adding +20 dB more to whatever is programmed.
I adjusted the reference level setting in the SA to compensate for the step attentuator extra attenuation, and i was able to see a peak for the first time! The peak level was completely off, and the frequency indicated by "peak search" was was by 2 MHz from 20 MHz, but I'll worry about that later. For now, my focus is to get the step attenuator to work. One step at a time
