If you keep analog front end from 3000T/4000, get rid of aMegazoom IV, put a single 16GS/s (a variant of?) converter from EXR (which would still get you 4GS/s in full channel mode, instead of 2,5GS/s now) and pipe that into Zynq, you would get immensely more powerful platform than now, and 10bit too.... You would literally solve all of the shortcomings of current platform. Pretty much what Rigol is doing, but with better performing components.
As for ASICS, they do bring a lot to the table, but not in this range anymore. For that range all can be done in FPGA now.
Then why hasn't anyone else done so with their Zynq based designs?
The Keysight is still the market leader in wavefor update speed and processing after 11 years.
Keysight made a whole bunch of new ASICS in the last few years.
New EXR and MXR have new ASICS (I guess Keysight spend their money in higher end offering) that enable real-time spectrum mode, DDC, frequency domain triggering etc etc... All of that at very high trigger rate.
[/quote]
Yeah, but you won't see those asic in a 3 or 4 digit priced scope I'm sure.
Also, people keep forgetting Infiniivision scopes are Keysight entry level scopes... Bottom of the offering range.
They won't make new version that has capability of EXR. If they make new version, it will be competitive with offering from other manufacturers in that range. So pretty much not much changes in way it is used and works for user, maybe bigger screen, better resolution and more memory. And that's it.. No more capability. They already newly refreshed mid range.
They won't create internal competition.
Maybe, but we still haven't seen a new design after 11 years, ASIC or not.
[/quote]
Rigol scopes have very fast WFM's per second. They are second fastest to Keysight. And it has nothing to do with what most people are referring to as "Keysights are fast". Keysights
are not fast to use because of Megazoom. Megazoom only helps with WFMs/s.
Rigols are almost as fast in WFMs/s but feel like molasses in comparison. Because user interaction is not done well.
The fact that (for instance) 3000T is so responsive is fact that Keysight did best job optimizing U/I. User input is priority 0 thread and everything stops as soon as you touch something. Also they did best job of optimizing background running threads and it's communication with hardware. Actual waveform rendering happens in hardware and is physically injected into screen area. That made it possible to have small CPU (that doesn't have graphics accelerator) and still be fast.
To be honest, all of that is also possible by the fact that 12000 USD scope has a screen with resolution that LESS than my hand watch.. Ruminate on that.
It is highly optimized user experience that is fast, not Megazoom. 1000X series has 1/5th of WFMs/s of 3000T and people still find it as fast. Because user experience was tuned for that.
Processing leader it is NOT. It (3000T) samples fraction of data even the cheapest scope now have, it does all measurements, filters, math on decimated 64k buffer. FFT is 64k max. Here, too, it cleverly trades off capability for speed.
BUT...
It is not a analytic scope. All the tradeoffs Keysight decided to do were done well, and with full understanding of it's target market and audience. It is a masterpiece of engineering: how to achieve most with as little as possible.
It is actual delicate balance of how much user gets while giving as little as possible.
Most users of these scopes are not bothered by low memory. It gets the job done.
Most users of these scopes are not bothered by low screen resolution. It gets the job done.
Most users of these scopes are not bothered by small screen resolution. It makes scope compact and easy to put on the desk. It gets the job done.
etc etc.
All while giving great user experience, instant response to user input. It is closest thing to CRT scope on market.
In its current form it gets the job done. No need to mess with it. There is no need for new design.
These scopes are Fluke 87 of scope industry.. Same rules apply.
Only when it stops selling they will offer something else. It's just good business.
Do I think they have at least rough draft on something new for that moment? Of course they do.
They are Keysight. And also being Keysight, you bet they can whip up new product in very little time.
In meantime they focus their effort on midrange/high end. Where their new corporate policy puts their priority.
They don't seem to care for entry level that much anymore.
