Author Topic: What?? New Aneng AN888S combines Multimeter, Bluetooth speaker, and clock  (Read 27299 times)
Offline ValverTopic starter
For the tech that has it all, now on Banggood, listen to your favorite music while taking measurements!
Oh, and it's an alarm clock also.
!885456-1
« Last Edit: December 06, 2019, 10:15:56 pm by Valver »
The following users thanked this post: edavid, Vovk_Z
Offline GreyWoolfe
  • NW0LF
Re: What?? New Aneng AN888S combines Multimeter, Bluetooth speaker, and clock
« Reply #1 on: December 06, 2019, 11:05:06 pm »
I doubt that I could sneak that past Mrs GreyWoolfe.
The following users thanked this post: Electro Detective
Offline sleemanj
  • Professional tightwad.
« Reply #2 on: December 06, 2019, 11:15:58 pm »
If you feel the need for a singing dancing multimeter, the "Aneng Official Store" (no idea if that is accurate) on Aliexpress has them cheap
https://www.aliexpress.com/item/4000343031770.html
Time display I can understand perhaps since it's logging (I think) so might be handy, radio.... scratching my head at that one.
Interestingly it's 18650 battery powered.
Offline I wanted a rude username
  • ... but this username is also acceptable.
« Reply #3 on: December 07, 2019, 12:19:29 am »
Why don't you spend the extra $20 and upgrade to the Aneng AN-8888S, with heated carbohydrate preparation function?
The following users thanked this post: tom66, David Aurora, stryker, BillyD, JohanH, Gandalf_Sr, totalnoob, Electro Detective, M1ch4L
« Reply #4 on: December 07, 2019, 12:38:06 am »
Actually, It seems to be a pretty decent meter for the price, .05% accuracy on all DC ranges.
Offline Fungus
« Reply #5 on: December 07, 2019, 04:05:27 am »
You can get just the meter for a lot less:
https://es.aliexpress.com/item/33004463675.html
The following users thanked this post: michalism, Valver
Offline floobydust
« Reply #6 on: December 07, 2019, 05:04:26 am »
Bluetooth for music but not my voltage readings? It's too bad, all that hardware wasted.
Offline rjp
« Reply #7 on: December 07, 2019, 06:36:37 am »
For me half the reason to get a bench one is to avoid the battery powered thing letting you down, its kinda nice to have it on the mains and just works (tm).
Offline sleemanj
« Reply #8 on: December 07, 2019, 07:08:47 am »
Actually, I think it probably doesn't have logging at all I was going by the fact it said "Data retention    √" but since there is clearly no BT for anything except the audio play back sillyness my guess is that they just mean it has a Hold button!
Also has a silly inverse LCD like was on that meter Dave reviewed a while back and had terrible battery life.
What a strange meter, I can't imagine why they would even think of designing such a thing.
Offline ralphrmartin
    • Me
« Reply #9 on: December 07, 2019, 06:54:21 pm »
April 1st seems to be very late this year? :-//
Offline Bud
« Reply #10 on: December 07, 2019, 07:18:54 pm »
All Chinese specifications at minimum are worse by 2 in reality.
« Reply #11 on: December 07, 2019, 10:15:21 pm »
Well then I've been pretty lucky
-885936-0
Offline Fungus
« Reply #12 on: December 07, 2019, 10:31:59 pm »
No they aren't.
https://www.eevblog.com/forum/testgear/another-cheapo-multimeter-19999-count-0-05-dc-accuracy/msg1456893/#msg1456893
The following users thanked this post: M1ch4L
Offline all_repair
« Reply #13 on: December 07, 2019, 11:42:24 pm »
So you can listen to AmpHour or eevblog when you are in your lab.  Not every phone has good speakers.
Offline MadScientist
« Reply #14 on: December 08, 2019, 10:06:44 am »
It’s not mains powered unfortunately
EE's: We use silicon to make things  smaller!
Offline JackJones
« Reply #15 on: December 08, 2019, 10:14:33 am »
I'd assume you can power it indefinitely through the USB port used for charging the 18650s.
I think it's kind of neat. I could see it in a compact lab where you don't have a lot of space.
Offline Electro Detective
« Reply #16 on: December 08, 2019, 10:33:47 am »
The features a tech really needs in a novelty meter, is a non nag female voice or patient cruisey guy (selectable) with a GPS vibe guiding you along with suggestions
and pending BANG! heads up   :o
and a warning beeper when a cheapass suss 'n deadly ThreeHungLow product is near the lab or repair bench,
so the appropriate PPE gear can be worn rather than loose BO enhanced singlet, shorts, and flip flops
Put me down for two of these meters if/when they are available   :-+
Offline Gandalf_Sr
« Reply #17 on: December 08, 2019, 10:48:29 am »
English is my first language and I don't understand what you wrote!
If at first you don't succeed, get a bigger hammer
The following users thanked this post: eliocor, edavid, tooki, jamesraykenney
« Reply #18 on: December 08, 2019, 10:36:37 pm »
Come on, it wasn't that cryptic mate  ;D  (I think.. :o )
A talking meter with a 'suspect MIC product' sensor
Talking meters aren't new btw, I have a Tandy/Radio Shack DMM kicking around somewhere..  :-//
worked great for a short while till the flimsy stranded 'press to talk' probe cable died.
hmm, will have to get on to that, it was great getting the readings 'read out' without looking at the meter  :clap:
« Reply #19 on: December 08, 2019, 10:48:56 pm »
Please allow me to translate from stream-of-consciousness to formal English.  ;)
For an electronic engineer, the two most useful functions of a "novelty" multimeter are:
  • A synthesised voice which, in the patient style of a satellite navigation device, provides suggestions and warnings about impending mistakes the user may be making
  • A proximity detector sensitive to cheap gizmos from AliExpress which, upon detecting such device, sounds a warning tone reminding the user to don appropriate personal protective equipment
If and when such a multimeter becomes available, I shall buy two of them.
The following users thanked this post: Gandalf_Sr, tooki, Electro Detective, geogeo, jamesraykenney
Offline floobydust
« Reply #20 on: December 09, 2019, 12:14:29 am »
For now, we'll have to listen to AC/DC High Voltage on this multimeter...
Not that it has any Cat. rating and likely a danger connected to a charger while making measurements...
Offline DarrenWalker
« Reply #21 on: December 28, 2019, 09:30:43 pm »
https://youtu.be/UrfKr-9Cm8M
This is the ZOYI ZT-5566 version (Original OEM) It's surprisingly not a bad (desk/bench) multimeter!
Definitely a niche product but it's actually quite useable (and accurate!) .
« Last Edit: December 28, 2019, 09:34:56 pm by DarrenWalker »
Offline Mechatrommer
  • Country: my
  • reassessing directives...
« Reply #22 on: December 28, 2019, 10:48:56 pm »
if they publish this earlier, i will be interested but... i already have Aneng Q1 in quite similar form...  :--
Offline Muttley Snickers
  • Cursed: 679 times
« Reply #23 on: December 28, 2019, 11:06:17 pm »
I'd assume you can power it indefinitely through the USB port used for charging the 18650s.   I think it's kind of neat. I could see it in a compact lab where you don't have a lot of space.
They probably could have added handy 18650 charger to the features list.   :D
Offline geogeo
« Reply #24 on: December 28, 2019, 11:11:48 pm »
Sure, but how about one that listens? Alexa, switch to DC voltage.  Alexa, hold that value.
I'd like to see that! I wouldn't buy it, just like to see it.  :-DD
The following users thanked this post: uncle_sem
