Poll
How would you rate the quality of your DP832(A) ?
Works perfectly as advertised, no flaws, reliable
30 (43.5%)
Works OK, with only minor issues
35 (50.7%)
Works, but with major restrictions or flaws
2 (2.9%)
Does not work properly, hardly usable
0 (0%)
Does not work at all
2 (2.9%)
Total Members Voted: 69
Author Topic: What is your opinion of the Quality of the RIGOL DP832(A) ?  (Read 7872 times)
Offline WolfgangTopic starter
    • Electronic Projects for Fun
Re: What is your opinion of the Quality of the RIGOL DP832(A) ?
« Reply #25 on: September 30, 2018, 06:28:51 pm »
No, I did not know how this sticky thing worked, sorry. Now I do, thanks
Offline tooki
« Reply #26 on: September 30, 2018, 09:02:51 pm »
You should go and delete all your bump posts.
IMHO, there’s almost never a justification for bumping an old thread, and certainly not every old thread you can find. It just pollutes search results by making it look as though there was thread activity when in fact it was just spam.
The following users thanked this post: Pinkus, TiN, nugglix
« Reply #27 on: September 30, 2018, 10:54:37 pm »
They should be gone by now. Sorry.
Offline bson
« Reply #28 on: October 01, 2018, 10:49:47 pm »
I have a DP831, I rarely use it. That's why it's all the more annoying for me that the device sometimes reboots itself.
The DP832 used to do that with very early firmware.  Those problems were fixed a long time ago.
The following users thanked this post: Wolfgang
Offline Gandalf_Sr
« Reply #29 on: October 01, 2018, 11:31:49 pm »
I leave my DP832 on for days and it has never rebooted.
If at first you don't succeed, get a bigger hammer
« Reply #30 on: October 01, 2018, 11:46:03 pm »
When I did a long term drift test for voltage references, I had one on for months without any issue.
One incident happened, however: During a thunderstorm, I got a power outage (probably only a few seconds), but the DP832 rebootet and came up with outputs disabled. This is OK for safety reasons, I guess.
https://electronicprojectsforfun.wordpress.com/silly-circuits/silly-circuits-a-heated-lm723-reference/
Offline sdouble
« Reply #31 on: October 02, 2018, 06:06:37 am »
I have 5 DP832s in the lab but I never use them again due to them switching off by themselves. I did not buy them very recently, that's true, but those are not the very first units produced by Rigol either. Then, I switched to E36312A from Keysight... I took advantage of the low-current measurement... but those beast killed about 10 of my highly sensitive analog boards before I figured out the powering up issue. ...
« Reply #32 on: October 02, 2018, 02:34:37 pm »
Hi, if its less than 3 years you could ask RIGOL for a warranty case.
Better than sitting on the shelf :)
Offline SteveRosenlund
« Reply #33 on: October 12, 2018, 02:25:48 am »
I just ordered my second DP832 because the first one is so good and reliable.
