The #1 recommended DSO in this thread uses 2 ADC's each with 200 Mpts of memory support !
It's just a pity it can't zoom out and see it all:
Tell me why
in principle I can't zoom out with a 10M point capture buffer when my 1 GS/s GDS-1054B scope is set to 1ms/div. Yes, I know the technical reasons for it, but that I can zoom out under some circumstances and not others is, from a user's perspective,
arbitrary. So give me a
first principles based reason that I can't zoom out under those conditions, if being able to zoom out after a capture is performed is so incredibly important.
Whether you can zoom out or not on the scopes that behave as you prefer is
effectively arbitrary. It depends on your capture length, your timebase, your base sample rate, the number of channels you have active and the distribution of those channels over the available ADCs, and possibly other things I haven't considered.
In light of that, what matters is
how you control what gets captured and how much gets captured. What is certain is that the Siglent doesn't waste any memory even when capturing less than the specified buffer size: it instead uses the additional memory for additional captures and allows you to view those captures via the history mechanism. You can always ensure that the entire buffer is filled simply by setting your timebase appropriately. Just like, for the scope behavior you prefer, you can always ensure that you can zoom out after a capture by setting your timebase appropriately.
It's just a difference in philosophy. The Siglent's main advantage in this is that
everything is obvious up-front. What you see is what you're going to get, no more and no less. You have complete and direct control of the capture length and duration. With the mechanism you prefer, you have to
do the math, or pay attention to the little indicator at the top of the display, and your control over the capture time is much more coarse, limited to those selections that the scope gives you for the capture buffer length, and using something less than the total
wastes the rest unless you have the segments feature and fool around with it (segments are
not a first class citizen on the Instek).
Neither approach is particularly hard to deal with as a user. The approach you prefer is perhaps better suited to scopes with a small amount of display real estate. The Siglent approach is, I'd argue, better when you have a large display because you can use zoom mode on such scopes without incurring much of a real estate penalty, thus getting you the control advantages the Siglent's approach brings while at the same time being able to "zoom out" at will.
If you were
really interested in always being able to zoom out, you'd be arguing for something that
no scope manufacturer that I'm aware of implements: a fixed ratio of displayed waveform versus captured waveform at capture time.
