Hello all!
This is my first post here, so bear with me. I have searched this forum far and wide and have so far found no one with a similar issue reported.
I received a Siglent SDS1104X-E in the mail today. Opened it up and got it set up according to the quick start guide and everything was fine. I tried to check out the cursor functionality by pressing the appropriate "Cursor" cursor button, however, the Channel 2 button lit up. Odd. I pressed the "Cursor" button again, and the Channel 2 button turned off. At no point did the cursors show up on screen, nor did the cursor menu appear above the soft buttons. Pressing the "Measure" button selects/unselects Channel 3 in the same way without showing the measurement menu. Pressing the "Navigate" button enables/disables Channel 4 in the exact same way. None of these buttons fulfil their intended functions. I have also discovered that the "Adjust" encoder is not working; turning it to either side has no effect on multi-menu items. The first soft button is also not working to select the first item in the menu, instead, it acts as the "Menu On/Off" button (the Menu On/Off button, by the way, works as intended... I just don't need two of them). I have also noticed that none of the rotary encoders are working as intended. For example, the vertical position knob changes the v/div.
I managed to get the remote web interface working, and through this interface, tested all of the functionality of the buttons that aren't working. I was able to see/move cursors, get measurements to show up, etc. Event the web version of the rotary encoders works as intended. This leads me to believe that, somehow, the key bindings have been completely messed up. Is there any way I can fix this?
Firmware version reported under Utilities is 6.1.35R2.
U-Boot version is 8.1
FPGA Version is 2019-11-15
Hardware Version 01-05
Anyway, I'm really bummed. I'm not sure if I did something wrong or if there is some way to fix this. Perhaps I need to return the unit? Has anyone else encountered and been able to fix this issue?
Thank you,
Async
