Author Topic: What happens when you blow the input of a £6500 Siglent SSA 3075X Plus!  (Read 6266 times)
Offline inaxeonTopic starter
  • mattmillman.com
    • Matt's Tech Pages
Re: What happens when you blow the input of a £6500 Siglent SSA 3075X Plus!
« Reply #25 on: December 23, 2021, 10:50:50 am »
So you’re complaining that the device *you* damaged, and are reticent to have them repair for such a high cost, the same one for which they’ve kindly shown you TSP channel video for, to help you repair it and save you money? Nice. They didn’t HAVE to share that video with you.
The video they linked to is not about repair, or the instrument I have, barely even close. Additionally, a request for even a scrap of information like the part numbers for the switches was not honoured.
I'm happy to put it out there that I'm unimpressed with Siglent in this instance. I will however say a big thanks to the comments from other EEVBlog members who have been very helpful.
  • mattmillman.com
    • Matt's Tech Pages
« Reply #26 on: December 23, 2021, 10:51:42 am »
Any chance you checked the impedance of the front end with a VNA before disassembly?
Replacing the first HMC1118 will hopefully fix it.
If you're not super comfortable with hot air rework I recommend timing how long it takes to remove the original IC so you can use the same heat/time when installing the new one. Obviously you want to use as little heat as possible but it will probably take quite a bit.
I don't have a VNA unfortunately. Fairly comfortable with hot air rework, shouldn't be an issue.
Online TurboTom
« Reply #27 on: December 23, 2021, 10:51:47 am »
 :-// You may not have noticed that the video is courtesy of "The Signal Path" aka Shariar, who's a member on EEVblog as well. It's freely available on YT and Siglent hasn't any involvement in it except having supplied the VNA hardware to Shariar for testing.
Moreover, the instrument in the mentioned video is the 3.2GHz variety whereas the OP's broken unit is a 7.5GHz SSA which (internally) is a completely different animal.
Of course, despite all this it's a kind move by Siglent to provide a link to Shariar's video even though it wouldn't help much regarding the repair of the OP's broken instrument.
Regarding the repair itself: Great care must be taken when doing hot air rework on these hybrid PCBs in order to not lift any pads or traces. This is exacerbated since lead free solder is used and the HMC1118 has an exposed pad that's soldered to the bulk of copper (GND) that's probably also VIA-stitched to underlying ground layers. I wouldn't even attempt this procedure without a decent (IR) heater from the other side of the PCB. Only hot air from the top most likely won't do the job.
For installation of the replacement part(s), I'ld definitely use leaded or even special low-temp solder in order to reduce the risk of collateral damage...
Edit: Just noticed that the OP commented on this topic while I was typing...
« Last Edit: December 23, 2021, 10:53:38 am by TurboTom »
  • mattmillman.com
    • Matt's Tech Pages
« Reply #28 on: December 23, 2021, 11:05:27 am »
IR heater? Wow man that is full on. I recently re-worked a QFN 24 on a non RF PCB which had heavy stitching to the internal GND layer. It was a piece of cake. You really think I need an IR heater? I usually just pass the hot air from side to side and heat it gradually.
« Reply #29 on: December 23, 2021, 11:09:25 am »
As this is a very near new SA and top of this range, Siglent's position is such that only new replacement parts can can be sure of delivering guaranteed performance. Having their service shop repair it with new parts would also ensure the warranty remained intact rather than have a owner repair it.
I'm on my 3rd one having upgraded some steps from their first releases to the SVA1032X I have today.
The other 2 were sold to customers with some remaining warranty or warranty we covered ourselves.
Offline nctnico
« Reply #30 on: December 23, 2021, 11:13:56 am »
I don't think it is that bad. It is only a small QFN chip. If you apply heat on the other side of the board to pre-heat it with hot air and then desolder the chip it is very likely a piece of cake indeed. My approach would be:
0) set the hot-air to 330 deg C
1) Preheat the board from the opposite side (a 5 x 5cm area) using hot air
2) Desolder the chip by applying heat to a 4x4 cm area; not just the chip itself
3) Apply flux
4) Put the new chip on the board and align it
5) Heat again to solder the chip to the board (align by nudging it if necessary)
6) Apply extra tin to pads that don't have enough tin
Note 1: there is no step to remove tin; this is a process which can easely lift pads so don't do it
Note 2: I don't point the hot air so much at the chip itself but primarily onto the board. In the end the board needs most of the heat energy
« Last Edit: December 23, 2021, 01:00:15 pm by nctnico »
  • mattmillman.com
    • Matt's Tech Pages
« Reply #31 on: December 23, 2021, 11:44:01 am »
I was told by Siglent's European support that there is no board level repair facility in this area. If there was I would have opted for it.
The options presented to me were:
A) Pony up €3200
B) Fix it yourself.
Impressive would be "We'll take care of it" or "Fix it for €300" for example.
« Last Edit: December 23, 2021, 12:27:30 pm by inaxeon »
  • mattmillman.com
    • Matt's Tech Pages
« Reply #32 on: December 24, 2021, 02:12:40 pm »
Well FedEx have just been and gone with my Christmas bundle of Hittite. It's a success! I've fixed the 40dB attenuation and have it back to how it was.
A few notes, and lessons:
1) As was suggested to me, replacing a QFN on an RF PCB like this is a lot harder than a thinner digital PCB. I didn't end up heating from the underside but it still took a bit more heat than usual to do the job.
2) There are some foams around the SMA connectors which won't survive a heat gun. Cover them first.
3) Always protect your spectrum analyser with a transient supressor.
4) Don't expect any favours from Siglent if you end up in this situation
5) You can learn more about the input characteristic of the SSA 3075X Plus from the HMC1118 datasheet than you can from Siglent's, because, it's parked right at the input with almost no protection ;-)
Merry Xmas all and thanks for your help
The following users thanked this post: egonotto, edavid, colorado.rob, DC1MC, HobGoblyn, barycentric
Offline tv84
  • Country: pt
« Reply #33 on: December 24, 2021, 02:43:02 pm »
Well done!   :clap: :clap:
Now, convert it to a SVA.
The following users thanked this post: NCG
  • mattmillman.com
    • Matt's Tech Pages
« Reply #34 on: December 24, 2021, 02:55:00 pm »
Certainly no point in paying for software anymore now that my warranty is toast. Perhaps I'll leave reading the 1000 forum pages about this till next year ;-)
Offline nctnico
« Reply #35 on: December 24, 2021, 04:32:47 pm »
Great! Nice job.
Online 2N3055
  • Country: hr
« Reply #36 on: December 24, 2021, 06:49:07 pm »
Congrats on fix!
I just want to comment that you seem to expect that Siglent should provide service that is nonexistent with ANY other manufacturer out there...
Nobody does component level repairs anymore, for many years. They might replace board and send broken one for rework to central facility.
Anyways good to hear good news.
Marry Christmas to all!!
  • mattmillman.com
    • Matt's Tech Pages
« Reply #37 on: December 24, 2021, 09:24:30 pm »
I just looked back over all of my posts. I couldn't see any where I'd said I expect Siglent to provide such a service? I certainly would have been impressed if they did.
Have a look at this video. It's by a guy, who blew the input of an SSA, exactly the same way that I did, doing the exact same thing. Skip to the 1:30 mark.
He apparently has been offered a free repair. If this is true, I certainly would like to know what qualifies him for that, but not myself? I was not asking for a free repair, just a bit less than a €3200 bill to sort out such a minor mishap.
Although he is Chinese, him and his business are based in the UK, just as myself. We ought to be talking to the customer same customer service team too. Why such different treatment? As I said I am assuming that assertion is true.
« Last Edit: December 24, 2021, 09:42:03 pm by inaxeon »
Offline Bud
« Reply #38 on: December 24, 2021, 10:03:06 pm »
You just answered your own question.
Online wraper
  • Country: lv
« Reply #39 on: December 25, 2021, 12:46:40 pm »
IMHO if you contacted them and just said that it failed, you probably would be offered a free repair. But I guess you contacted them and said you blew up the input.
Online 2N3055
  • Country: hr
« Reply #40 on: December 25, 2021, 05:59:16 pm »
Thank you for clarification, I missed that.
I guess there is a difference between entry level inexpensive instrument and one that cost 5 times as much.
Also, we don't really know how that person reported problem to point of sale. Maybe it was accepted as a warranty claim, not as user damaged equipment...
In your place, I would not expect Siglent to repair for free. If they did, I would be happy, but certainly they wouldn't owe it to me to do so.
Also, don't take for granted what people with Youtube channels say, or think that the way how manufacturers treat them is same as everybody else. They sometimes not only get offered free repairs, but all kinds of free  equipment in the first place in exchange for reviews or simply web presence...
But all that is a moot point now. Most important thing is that you, with your competence and knowledge, were able to repair expensive instrument. That was nice work.
I would, if I may, would like to invite everybody to a discussion as to how they protect their SA inputs from damage in various potentially dangerous situations. That would be one very useful topic for us all.
  • mattmillman.com
    • Matt's Tech Pages
« Reply #41 on: December 25, 2021, 09:48:01 pm »
For what I was doing, appropriate protection is something like this: https://www.tekbox.com/product/tekbox-tbfl1-transient-limiter/
It'd limit you to 600MHz but that's plenty for EMC work. Outside of this there probably isn't such a need for protection as you aren't likely to see unexpected overloads.
Online G0HZU
« Reply #42 on: December 26, 2021, 08:22:06 pm »
I have several overload limiters here depending on the application. See the image below. The one circled in yellow just contains two pairs of back to back 1N4148 diodes. This has very low insertion loss and very low VSWR. I think the the loss is about 0.1dB at 1GHz and the VSWR is typically 1.05:1.
It only provides effective limiting to about 500MHz though. It also only provides brief protection but should survive 5W of RF for a few seconds. It looks a bit ugly but the RF performance is very good.
The limiter to the left also has an RF fuse and a DC block fitted. This has slightly more loss but it should blow the RF fuse once the limiter diodes conduct. This limiter may well protect at >10W RF power but I'm not sure how quickly the fuse will blow. It should hopefully blow before the limiter diodes fail. I did test it numerous times and the fuse blew in a split second as long as the RF power was above 3W.
The other limiters are pretty much the same except one of them is suitable for AF through to about 20MHz. This has a DC block and a fuse.
For frequencies from VHF through many GHz I also have some PIN diode limiters but these will probably only protect up to about 3W.
Offline nctnico
« Reply #43 on: December 26, 2021, 09:16:32 pm »
As I wrote before: if the SA doesn't have a resistive attenuator as the first stage, a good start would be to fit an external 10dB attenuator so whatever protection is in the semiconductor has a fighting chance to cope with a surge coming in.
« Reply #44 on: December 26, 2021, 10:57:56 pm »
These do have auto default attenuation settings that when turned OFF expose the unit to user errors.
There are times when you need auto attenuation OFF however they are relatively rare when instead you can leave the instrument to mostly protect itself.
When I got my first, a SSA3032X worries about damaging the RF input were very high so I got the Utility kit that has a selection of adapters, cables and an attenuator which after gaining some confidence I rarely used again.
https://siglentna.com/product/ukitssa3x-utility-kit/
« Last Edit: December 26, 2021, 11:05:44 pm by tautech »
Offline nctnico
« Reply #45 on: December 26, 2021, 11:28:12 pm »
Did you even look at the circuit board? From the input the signal goes straight into a chip without any protection whatsoever. This is a big no-no in any design because it is extremely sensitive to damage.
Online G0HZU
« Reply #46 on: December 26, 2021, 11:37:42 pm »
I dug out my homebrew (precision) protection limiter (the one circled in yellow below) and measured it for insertion loss and return loss. This limiter was very carefully designed to allow me to use it ahead of a thermocouple power meter or a spectrum analyser and to not have to worry about adding correction offsets for the majority of measurements. The ultra low insertion loss and ultra low VSWR mean that it doesn't really contribute much to measurement uncertainty.
You can see the scale for insertion loss is 0.1dB and the return loss is better than 40dB out to 1GHz. The limiter circuit is really simple but the key to the RF performance is in the choice of decent Suhner bulkhead connectors and careful RF layout in the small metal enclosure. You can see that I just soldered the two bulkhead connectors the ideal distance apart and the tight metal enclosure helps to preserve the optimal return loss and insertion loss.
The limiter only provides robust protection up to about 500MHz but it does limit to some degree above this.
« Last Edit: December 26, 2021, 11:39:35 pm by G0HZU »
The following users thanked this post: 2N3055, inaxeon, miken
Online G0HZU
« Reply #47 on: December 26, 2021, 11:49:10 pm »
See below for the other limiter that is just to the left of the previous one. This one has a DC block included and also an RF fuse. This means the insertion loss is a bit higher and the RF fuse limits the bandwidth. However, it still has very good performance up to about 200MHz.
See the plots below. This is the limiter I use if I play with any amateur radio stuff from LF through to 145MHz. The RF fuse may be able to protect against really high power 'accidents' but I've only tested it to about 5W. It's arguably a better limiter than the precision limiter because it has the RF fuse included. This added protection is a good tradeoff against the 0.25dB insertion loss up at 145MHz.
  • mattmillman.com
    • Matt's Tech Pages
« Reply #48 on: December 27, 2021, 08:47:51 pm »
You are not wrong about that however we have to expect this for an instrument at this price point.
Online 2N3055
  • Country: hr
« Reply #49 on: December 27, 2021, 10:16:28 pm »
What do you mean? Most of SAs out there would probably be damaged by same event, especially wide bandwidth expensive ones. SA front ends are not robust at all, and are made for best RF specs not survivability. There are very few that are bit more robust than others, but those are not norm.
The following users thanked this post: Performa01
