Author Topic: Rigol DS1202z-e external trigger  (Read 1160 times)
Offline ftsTopic starter
« on: December 01, 2020, 11:33:40 am »
I try to utilize the external trigger input on the Rigol DS1202z-e but it doesn't seem to work. All works fine if i connect the same signal to one of the analog inputs and use it as trigger source.
Setup:
 - 1kHz 3.3V Signal via x1 probe on ext trigger input.
 - trigger source "EXT"
 - slope "rising edge"
 - trigger level 1.5V
 - trigger mode normal
The trigger indicator keeps blinking "WAIT". Any suggestions on what I'm doing wrong?
Offline Fungus
Re: Rigol DS1202z-e external trigger
« Reply #1 on: December 01, 2020, 12:15:40 pm »
Have you tried x10 probe?
« Reply #2 on: December 01, 2020, 02:12:52 pm »
yes, but it didn't work either.
Offline Fungus
« Reply #3 on: December 01, 2020, 02:36:41 pm »
What about trigger coupling, AC or DC?
« Reply #4 on: December 01, 2020, 02:48:20 pm »
trigger coupling is fixed to "DC" when using the external trigger. I also tried different slope settings (rising, falling, any), no luck.
« Reply #5 on: December 13, 2020, 04:58:26 pm »
My device was defective. Got it exchanged, it's working fine now.
The following users thanked this post: Fungus
