Does anybody have experience with the Compress command on the 856X Spectrum analyzers? I assume you can only use it from GPIB? I've seen examples of 3 plots on one screen and though I could do the same with a Labview or Visual Basic application, I would like to take a crack at using the analyzer.
From the simple example I read, it looks like you can compress the trace and store it into one of the trace memories like A,B,C. I don't see an example of where you then position the traces on the screen.
I picked up a beautiful 8568B about a month ago to supplement my Advantest portable analyzer. Over the weekend I was able to find the RF preselector (85685a) again for what I thought was a good deal. In reading thru some of the lit I found the multiple trace screens somewhat interesting for an old box like this.
Thanks
