My oscilloscope just arrived, Tequipment sure has a funny way of packaging by placing it within 3 boxes.
Scope performance is really nice, at 1ms timebase at 200Mhz i get the full spec of 1GSa/s and 10M, any longer and only the sampling rate halves. It could definitely use more apps and software but i havent managed to update the firmware yet. This scope is very sensitive, what i thought the scope was very noisy but currently until i move into a much bigger room i have so many electronics around such as my wifi AP sitting next to it, putting the probes near the back of my monitors or even near the bench PSU showed similar AC like noise. This is down at 1mV. It is also nice that i can get the scope down to 1ns timebase. USB and ethernet work the way i want them to although i cant set a proxy but at least i can force it using my router.
I didnt have trouble with the interface, i could instantly access and use it without reading the manual and not having used a scope before. I guess some of you are too used to certain interfaces.
One thing i really wish they would add is NTP and locale setting as it set itself to china/taiwan's time. Once i move in July i will do a review on this as i would have a much bigger room, more space and perhaps set up a faraday cage.
quite impressed with the scope and it even has DMM functionality but it seems to measure differently than my handheld crappy DMM. Measuring 24.5V at bench PSU display during load, my DMM showed 24.3V, my router being powered by it showed 24.1V (putting DMM on cables showed a 0.1-0.2V loss). putting the oscilloscope showed around 23.8V at the output.
Edit: thanks Tequipment for the extra boxes, i now have more boxes i need for moving.
