Author Topic: JunTek PSG9080 Programmable Signal Generator (80 MHz - 300 MSa/s - 14-bit)  (Read 51981 times)
Online Kean
    • Kean Electronics
Allthough it does not answer my question, it is still a good suggestion.  ;D
Well,  you didn't state any clear question and just asked how it looked.
I agree it looks like they weren't thinking as the screw could short the traces, and I'm surprised it didn't get improved after the first batch - or at a minimum adding an insulating washer.
I've seen a lot worse, and on significantly more expensive equipment.
I rarely use my PSG9080.  If I did need it more often, I would certainly consider replacing it with a Rigol or Siglent.  You made a good decision.
Offline eTobey
On which one and what there was worse?
"Sometimes, after talking with a person, you want to pet a dog, wave at a monkey, and take off your hat to an elephant." (Maxim Gorki)
