Author Topic: GPIB or HP-IB with HP 8595E Spectrum Analyzer?  (Read 3797 times)
Offline RCHRDMTopic starter
« on: December 31, 2016, 07:13:12 pm »
I just got an Agilent GPIB or HP-IB USB adapter that works great on my Agilent signal generator (at least to send commands).  However, when I plug it into my HP 8595E spectrum analyzer, the Keysight Connection Expert does not seem to recognize the instrument.  It sees the HP-IB address (18) but shows no connection.
Is there different software or a different procedure to use here?  I thought that GPIB or HP-IB was the same for all instruments, old or newish.
Richard
Offline bingo600
Re: GPIB or HP-IB with HP 8595E Spectrum Analyzer?
« Reply #1 on: January 01, 2017, 11:51:17 am »
GPIB/HPIB is 2 names for the same "electrical interface"
That said , the instrument commands are different for many instrument types (classes) , and expecially if it's pre SCPI.
It might be that the sw doesn't support the SA , have you verified that it does ??
/Bingo
Offline HighVoltage
« Reply #2 on: January 01, 2017, 12:19:31 pm »
The old HP SA have no SCPI support.
Take a look here, this is may be what you are looking for
http://www.ke5fx.com/gpib/readme.htm
The KE5FX GPIB Toolkit is a collection of free Windows utilities that will help you make and record research-quality measurements with GPIB-based electronic test equipment.
This is version 1.971 of the Toolkit, released October 28, 2016.
Offline pe1oxp
  • ~ Life is too short for QRP ~
« Reply #3 on: January 01, 2017, 12:52:40 pm »
Manual sending *IDN? should work.
Haven't connected my 8594E at the moment so I can't verify it.
Offline HighVoltage
« Reply #4 on: January 01, 2017, 01:46:55 pm »
*IDN? is a SCPI command, NOT working on most of the older HP gear.
Most likely the HP Spectrum Analyzer will not respond at all.
Offline MarkL
« Reply #5 on: January 01, 2017, 02:09:41 pm »
The command is "ID".  It will return the model number:
  HP8595E
Programmer manual here:
  http://literature.cdn.keysight.com/litweb/pdf/08590-90235.pdf
Offline pe1oxp
« Reply #6 on: January 01, 2017, 02:17:24 pm »
You are right, according to the programming manual sending ID? should return the model number.
« Reply #7 on: January 01, 2017, 04:28:28 pm »
Thanks very much for the information!
I looked again, and it seems that the Keysight Connection Expert does see the spectrum analyzer.  I have downloaded the GPIB tools and will try them out.
Happy New Year!
Richard
