Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Test Equipment
Yokogawa Bench Meters, Slim Pickings.
« previous
next »
Print
Search
Pages:
Prev
1
2
3
All
Go Down
Author
Topic: Yokogawa Bench Meters, Slim Pickings. (Read 23262 times)
2N3055
Super Contributor
Country:
Re: Yokogawa Bench Meters, Slim Pickings.
Reply #50 on:
February 21, 2022, 07:20:37 am »
My 7562 has LT1021 as reference.
Looking at the board at the time, there are unpopulated pads for a LM399 and a opamp, I guess also for a 10V circuit..
Logged
man216
Newbie
Country:
Reply #51 on:
March 30, 2023, 07:23:33 pm »
Hello guys! I just purchased this Yokogawa 7552 Bench Multimeter for myself. Can you tell me if it has an audio continuity feature? Thank you.
Logged
maxwell3e10
Frequent Contributor
Country:
Reply #52 on:
April 02, 2023, 05:02:15 pm »
I setup a continuity check using the limit checking pass/fail output. Put a buzzer in the back and program hi/low limits for resistance. It helps to have the memory card, so one does not need to reprogram the limits every time the meter is turned on.
Logged
scopeman
Country:
Reply #53 on:
April 04, 2023, 12:56:20 am »
A couple pf years ago I bought on close out a Iwastu VOAC 7062 which is Identical to the Yokogawa DM7560 6 1/2 digit DMM. As Yokogawa built these for Iwatsu the quality is excellent. There is a teardown of these units on the forum.
As you may know one of the divisions of HP was YHP Yokogawa HP. The VOAC 7062/DM7560 have voltage reference chips (heated buried Zener like LM395 IIRC) that are marked with an HP part number.
This is no surprise as I believe YHP builds or built some DMM products for HP and perhaps continues to do so. The DM7560 is very similar to the current 6 1/2 digit DMM's of late from HP/Agilent/Keysight.
YHP was most famous for their LCR Meters and Bridges and I believe the HP9342? Q meter and the HP4329 HiZ meter among other products. Top quality all the way.
Enjoy your new meter!
Sam
W3OHM
Logged
W3OHM
Print
Search
Pages:
Prev
1
2
3
All
Go Up
« previous
next »
Products
Test Equipment
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
