Author Topic: Voltage sources/DAQs for characterising VCOs/OCXOs  (Read 523 times)
Offline philpemTopic starter
  • That Sneaky British Bloke
« on: April 04, 2023, 12:45:43 am »
Ayup!
In a past life I worked on the hardware and software for industrial control kit. 4-20mA, 0-10V, that sort of thing. Occasionally we'd need do linearity and hysteresis tests by feeding in a variety of 0-10V ramps and measuring the process output. I'm finding myself needing to do something similar for a VCO design.
At that place we had a fleet of Yokogawa GS210s and 7261s (precision DC voltage/current sources) which were great for this -- hook them up to a PC via USB, hook up a measuring instrument for the output, run a script on the PC to step through the various ramps. I've had a look at pricing but £1k+ is more than I'd want to spend for something I wouldn't use all that often.
I've had a dig around elsewhere and discovered the NI USB-6009 DAQ, which has two 0-5V analog outputs with 12-bit resolution. That's probably fine -- but it'd be useful to have 0-10V and bipolar (+/-5V or +/-10V) ranges too. Analog-in isn't really necessary, I have other instruments for that.
Does anyone know of something like the NI USB-6009 DAQ or the Yokogawa instruments, but with a wider output voltage range?
Output current requirement would be a few milliamps at most, to drive a varactor diode or some kind of input stage.
Update rate - once a second is fine, the settling time on the measurement will be longer.
I've thought about homebrewing something out of a bandgap reference, some 12- 14- or 16-bit DACs, an amplifier stage and a microcontroller -- but that seems like hard work I'd rather put into my fancy RF designs, if there's some off-the-shelf kit I can use instead!
Cheers
-Phil
Phil / M0OFX -- Electronics/Software Engineer
"Why do I have a room full of test gear? Why, it saves on the heating bill!"
Offline dobsonr741
Re: Voltage sources/DAQs for characterising VCOs/OCXOs
« Reply #1 on: April 04, 2023, 03:39:24 am »
Take a look at ADALM1000 and ADALM2000, from Analog Devices. Usual retailers carry. Not exactly what you want, but close. Maybe you just need a precision amp.
The following users thanked this post: philpem
