Tek 515A, Hardcore Restoration.
1. cleaning inside (there is no outside...
you know that, washing, drying.... ![](http://www.wellenkino.de/515A-2/3.jpg)
2. electronic repair.
Tubes was complete but I found a defect double triode and some interrupted cables from bad handling without case.
Also was some replacement of cermaic C in the high voltage area required, following tests and recalibration
![](http://www.wellenkino.de/515A-2/r2.jpg)
a time later "for parts" waked up.
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
3. Removing the PC-fan I found there and do a replacement with a original Tek fan.
Rebuilding of the complete cover including the filter frame...
In my collection is a second 515A, this I used for measuring and planing the rebuild parts for my "for parts".
Rebuilding of the filter frame, from Aluminium sheet 1.5mm. cutting, folding, forming corners, welding the cut, make that straight at the corners with sandpaper
![](http://www.wellenkino.de/515A-2/r6.jpg)
![](http://www.wellenkino.de/515A-2/r7.jpg)
![](http://www.wellenkino.de/515A-2/a.jpg)
![](http://www.wellenkino.de/515A-2/b.jpg)
drawing the Covers in CAD, convert this to CNC data and cutt the sheets on a nibble mashine at my work.
Then i foldet them on the press brake exacty, the large corner is a half inch. There was no tool in this size, so i used a selfmade.
done
the new covers of "for parts"
![](http://www.wellenkino.de/515A-2/r3.jpg)
following the test if the new jacket will pass?
![](http://www.wellenkino.de/515A-2/5.jpg)
looks good, "for parts" is now a Tek515A.
Then I have sent the covers and the filter frame to a burn pinter company to make that Tek blue.
They was blind in colors, wrong blue... but OK, this is so or so a very special Tek...
no Tek blue
my 515A![](http://www.wellenkino.de/515A-2/9e.jpg)
greetings
Martin
