Haha, I won't collect all of them like you do!
Right now I own the following models:
Tektronix 310A (
021904)
Simply one of the most amazing mechanical design that can be seen on a glowy test equipment. I got this one for my own collection only, pretty much. It's a masterpiece of vintage electronics test gear... It has a limited 4MHz bandwidth but definately enough for audio work for example and some analog projects.
Tektronix 547 (
013807) -
soon -
The 547 is the top of the line when refering to single beam oscilloscopes of the 500-series. Makes use of all their technological advances, including the exclusive "Automatic Display Switching" feature, which can be really useful in some situations. Still not the fastest of the 500-series, which is the 585 as far as I remember.
Tektronix 454 (
B276947)
This is the scope that I'm using for my projects right now. This is the last model that makes use of those super sharp CRTs as far as I know. It follows the 453 which was designed for IBM when they asked for a portable oscilloscope that technitians could bring along with them when travelling. It was made for computer work back in the 60's - 70's. The 453 is the oscilloscope that introduced the rotating handle. The 454 is basically the 453 with a tripled bandwidth. The 454 is the fastest analog oscilloscope that uses only discrete components, no custom ICs.
Tektronix 221 (
B054502)
This one is a cute small oscilloscope! Litterally the nicest looking small analog oscilloscope to date. I tend to bring this one with me when I have to debug some analog circuits. This is the fastest model of this line, there are all the other models, dual trace storage, integrated dmm or simply dual trace. This one is single trace but has a 5MHz bandwidth which is a lot more useful to me than dual trace and 500kHz, but I can't compare signals.
Tektronix 2465B (
B055041)
This was my first Tek oscilloscope I got years ago, still my main bench oscilloscope. I was not into collecting Tek scopes back then... the madness started later.
Before that I used a digital Rigol 1052E which was kind of horrible when trying to debug the analog circuits of my CRT driver boards project. This is probably the fastest portable analog oscilloscope. Despite being analog, its OSD has some really nice features that helps with quick measurements, but I should not get used to that too much
This is what I have in mind:
Tektronix 585ASimply the fastest of the 500-series oscilloscopes (excluding the oddball 519)! It reaches 100MHz easily with tube based circuitry. It has 4 transistors though, so it's not a vacuum tube only equipment, it's a hybrid. This one uses special plugins to reach such a high bandwidth but can still accept slower regular 1-series and letter-series plugins via an adapter.
Tektronix 555 (aka "Triple Nickel")
This is a monster... This model is not the fastest dual beam in the 500-series, that would be the 556. But I admire this model with its separate power supply that uses a saturable reactor design to regulate the voltage of all the tube filaments in the entire oscilloscope. It takes not only the two vertical plugins, but also two horizontal timebase plugins. This is probably the most power hungry of all the Tek oscilloscopes with 1kW as far as I remember...
Tektronix 556If going for a dual beam Tek from the 500-series, this is the top of the line. It's, I guess, the replacement for the great 555 but unlike this one, it does not use horizontal plugins. It's like two Tek 547 in one box. A lot of combinaisons are possible between the top/lower beams, the A/B timebases and the left/right plugins. For example it's possible to display one same signal through a vertical amplifier plugin in one bay, and a spectrum analyzer plugin in the other bay.
Tektronix 519This one is unlike any other 500-series scope. It is a blazing fast 1GHz analog oscilloscope made in the early 60's... No vertical amplifier, the signal goes straight to the delay line and the deflection plates of the CRT. Is uses special connectors and has a 125-ohm input impedence. This is definately not the every-day use test equipment, but it is definately an awesome collection piece!
Tektronix 515A / 516There is nothing incredible about these two, but those are nice smaller oscilloscope models that still makes use of big 5" CRTs. They both have a 15MHz bandwidth which is plenty enough for a lot of projects, if using them on a regular basis and not only for the collection. I'd say it would be a smaller version of the 533, or something close, but without the vertical plugin bay. The 515 is a single trace model with a switch to select between two inputs, and the 516 is a dual trace model. The difference between the 515 and 515A is that the A version has an external Z-axis input and slightly higher sensitity.
And there is the 7k series oscilloscopes which are probably the best of all the analog oscilloscopes with a plugin-style design. Great stuff! No tubes involved here of course, and a lot of proprietary ICs.
Something I'm going to build soon is a fast edge pulse generator that I'll use to measure the rise time of the oscilloscopes I own and determine their maximum bandwidth. There are a few different ways of doing something like that, and one of them is using the avalanche pulse generator design from Jim Williams. I have a Tektronix BNC accessory housing, so I'll see if I can use it for that project.
