Author Topic: Good probe for noise and ripple?  (Read 2640 times)
Offline AlanRTopic starter
« on: March 23, 2014, 09:32:46 pm »
I just recently threw down $1000 for a  Cal Test CT3688 active differential probe. Here is the datasheet: http://disti-assets.s3.amazonaws.com/straightroadelectronics/files/datasheets/2023.pdf
You guys think I should have went with a different probe that may be better? I have searched, but the others had worst specs than this one.
Offline robrenz
  • Real Machinist, Wannabe EE
Re: Good probe for noise and ripple?
« Reply #1 on: March 23, 2014, 09:41:42 pm »
Isn't that 10X attenuation going to hamper seeing low level signals? Even if your scope has 0.5mV/div that will be 5mV/div after the probe. Is that going to work for you?
« Reply #2 on: March 23, 2014, 09:47:26 pm »
I can send it back. I need one that has low noise and low offset errors with 1% or better accuracy. I have a $3000 budget for one.  If push comes to shove I'll just build a differential amp front end.
Offline robrenz
« Reply #3 on: March 23, 2014, 09:57:04 pm »
« Reply #4 on: March 23, 2014, 10:09:11 pm »
THANKS!! I have decided on the SIM910 preamplifier. Looks like it is time to send back the differential probe. :-+
EDIT: eehhh, only 1 MHz bandwidth.
« Last Edit: March 23, 2014, 10:17:37 pm by AlanR »
Offline w2aew
    • My YouTube Channel
« Reply #5 on: March 24, 2014, 12:45:01 am »
If you have a late model Tek scope that uses the Tek-VPI probe interface, the TPP0502 is a 500MHz, passive probe that is only 2X attenuation - really nice for these types of measurements.
FAE for Tektronix
Online nctnico
« Reply #6 on: March 24, 2014, 12:56:14 am »
How about not using a probe and feeding the signal through a BNC or SMB connector directly into the scope?
