Hello,
after update firmware my Hantek DSO1202BV scope didn’t boot succesfully.
Firmware was originaly from sites of Hantek.
I have connected to internal USART and i find that machine is alive.
It seems the YAFFS2 filesystem is corrupted.
Have you contact for anybody from service Hantek?
Could you send me a backup or factory file please?
Or its possible to repair the filesystem?
Log from Putty:
##### EmbedSky BIOS for SKY2440/TQ2440 #####
Press Space key to Download Mode !
Booting Linux ...
Copy linux kernel from 0x00200000 to 0x30008000, size = 0x00200000 ... Copy Kernel to SDRAM done,NOW, Booting Linux......
Uncompressing Linux... done, booting the kernel.
Linux version 2.6.30.4 (root@rain-fc4) (gcc version 4.3.3 (Sourcery G++ Lite 2009q1-176) ) #111 Fri Aug 26 16:40:17 CST 2011
CPU: ARM920T [41129200] revision 0 (ARMv4T), cr=c0007177
CPU: VIVT data cache, VIVT instruction cache
Machine: TQ2440
ATAG_INITRD is deprecated; please update your bootloader.
Memory policy: ECC disabled, Data cache writeback
CPU S3C2440A (id 0x32440001)
S3C24XX Clocks, (c) 2004 Simtec Electronics
S3C244X: core 400.000 MHz, memory 100.000 MHz, peripheral 50.000 MHz
CLOCK: Slow mode (1.500 MHz), fast, MPLL on, UPLL on
Built 1 zonelists in Zone order, mobility grouping on. Total pages: 16256
Kernel command line: noinitrd root=/dev/mtdblock2 init=/linuxrc console=ttySAC0
NR_IRQS:85
irq: clearing pending ext status 00080b00
irq: clearing subpending status 00000002
PID hash table entries: 256 (order: 8, 1024 bytes)
Console: colour dummy device 80x30
console [ttySAC0] enabled
Dentry cache hash table entries: 8192 (order: 3, 32768 bytes)
Inode-cache hash table entries: 4096 (order: 2, 16384 bytes)
Memory: 64MB = 64MB total
Memory: 61260KB available (3160K code, 346K data, 100K init, 0K highmem)
SLUB: Genslabs=11, HWalign=32, Order=0-3, MinObjects=0, CPUs=1, Nodes=1
Calibrating delay loop... 199.47 BogoMIPS (lpj=498688)
Mount-cache hash table entries: 512
CPU: Testing write buffer coherency: ok
net_namespace: 296 bytes
NET: Registered protocol family 16
S3C2440: Initialising architecture
S3C2440: IRQ Support
S3C24XX DMA Driver, (c) 2003-2004,2006 Simtec Electronics
DMA channel 0 at c4808000, irq 33
DMA channel 1 at c4808040, irq 34
DMA channel 2 at c4808080, irq 35
DMA channel 3 at c48080c0, irq 36
S3C244X: Clock Support, DVS off
bio: create slab <bio-0> at 0
SCSI subsystem initialized
usbcore: registered new interface driver usbfs
usbcore: registered new interface driver hub
usbcore: registered new device driver usb
cfg80211: Calling CRDA to update world regulatory domain
NET: Registered protocol family 2
IP route cache hash table entries: 1024 (order: 0, 4096 bytes)
TCP established hash table entries: 2048 (order: 2, 16384 bytes)
TCP bind hash table entries: 2048 (order: 1, 8192 bytes)
TCP: Hash tables configured (established 2048 bind 2048)
TCP reno registered
yaffs Aug 26 2011 11:40:43 Installing.
msgmni has been set to 119
alg: No test for stdrng (krng)
io scheduler noop registered (default)
backlight initialized
s3c2440-uart.0: tq2440_serial0 at MMIO 0x50000000 (irq = 70) is a S3C2440
s3c2440-uart.1: tq2440_serial1 at MMIO 0x50004000 (irq = 73) is a S3C2440
s3c2440-uart.2: tq2440_serial2 at MMIO 0x50008000 (irq = 76) is a S3C2440
loop: module loaded
Driver 'sd' needs updating - please use bus_type methods
S3C24XX NAND Driver, (c) 2004 Simtec Electronics
s3c2440-nand s3c2440-nand: Tacls=2, 20ns Twrph0=3 30ns, Twrph1=2 20ns
NAND device: Manufacturer ID: 0xec, Chip ID: 0x76 (Samsung NAND 64MiB 3,3V 8-bit)
Scanning device for bad blocks
Bad eraseblock 365 at 0x0000005b4000
Bad eraseblock 4073 at 0x000003fa4000
Creating 4 MTD partitions on "NAND 64MiB 3,3V 8-bit":
0x000000000000-0x000000040000 : "EmbedSky_Board_uboot"
0x000000200000-0x000000400000 : "EmbedSky_Board_kernel"
0x000000400000-0x000003ff8000 : "EmbedSky_Board_yaffs2"
0x000000100000-0x000000200000 : "EmbedSky_Board_logo"
ohci_hcd: USB 1.1 'Open' Host Controller (OHCI) Driver
s3c2410-ohci s3c2410-ohci: S3C24XX OHCI
s3c2410-ohci s3c2410-ohci: new USB bus registered, assigned bus number 1
s3c2410-ohci s3c2410-ohci: irq 42, io mem 0x49000000
usb usb1: configuration #1 chosen from 1 choice
hub 1-0:1.0: USB hub found
hub 1-0:1.0: 2 ports detected
Initializing USB Mass Storage driver...
usbcore: registered new interface driver usb-storage
USB Mass Storage support registered.
usbcore: registered new interface driver usbserial
USB Serial support registered for generic
usbcore: registered new interface driver usbserial_generic
usbserial: USB Serial Driver core
USB Serial support registered for pl2303
usbcore: registered new interface driver pl2303
pl2303: Prolific PL2303 USB to serial adaptor driver
mice: PS/2 mouse device common for all mice
S3C24XX RTC, (c) 2004,2006 Simtec Electronics
s3c2410-rtc s3c2410-rtc: rtc disabled, re-enabling
s3c2410-rtc s3c2410-rtc: rtc core: registered s3c as rtc0
Linux video capture interface: v2.00
S3C2410 Watchdog Timer, (c) 2004 Simtec Electronics
s3c2410-wdt s3c2410-wdt: starting watchdog timer
s3c2410-wdt s3c2410-wdt: watchdog active, reset abled, irq enabled
mapped channel 0 to 0
s3c2440-sdi s3c2440-sdi: powered down.
s3c2440-sdi s3c2440-sdi: initialisation done.
mmc0: new SD card at address 1234
usbcore: registered new interface driver usbhid
usbhid: v2.6:USB HID core driver
mmcblk0: mmc0:1234 SA02G 1.85 GiB
mmcblk0:<6>Advanced Linux Sound Architecture Driver Version 1.0.18a.
p1
No device for DAI UDA134X
No device for DAI s3c24xx-i2s
S3C24XX_UDA134X SoC Audio driver
UDA134X SoC Audio Codec
asoc: UDA134X <-> s3c24xx-i2s mapping ok
ALSA device list:
#0: S3C24XX_UDA134X (UDA134X)
TCP cubic registered
RPC: Registered udp transport module.
RPC: Registered tcp transport module.
lib80211: common routines for IEEE802.11 drivers
s3c2410-rtc s3c2410-rtc: setting system clock to 2001-10-10 08:44:13 UTC (1002703453)
yaffs: dev is 32505858 name is "mtdblock2"
yaffs: passed flags ""
yaffs: Attempting MTD mount on 31.2, "mtdblock2"
yaffs: block 109 is marked bad
block 110 is bad
yaffs: block 3817 is marked bad
block 3818 is bad
yaffs_read_super: isCheckpointed 0
VFS: Mounted root (yaffs filesystem) on device 31:2.
Freeing init memory: 100K
can't open /dev/tq2440_serial0: No such file or director
Pressing space after start:
##### Boot for Nand Flash Main Menu #####
[1] Download u-boot or STEPLDR.nb1 or other bootloader to Nand Flash
[2] Download Eboot to Nand Flash
[3] Download Linux Kernel to Nand Flash
[5] Download CRAMFS image to Nand Flash
[6] Download YAFFS image to Nand Flash
[7] Download Program (uCOS-II or TQ2440_Test) to SDRAM and Run it
[8] Boot the system
[9] Format the Nand Flash
[a] Download User Program (eg: uCOS-II or TQ2440_Test)
(b) Download LOGO Picture (.bin) to Nand Flash
[l] Set LCD Parameters
[r] Reboot u-boot
[t] Test Linux Image (zImage)
[q] quit from menu
Enter your selection:
q:
EmbedSky> help
? - alias for 'help'
autoscr - run script from memory
base - print or set address offset
bdinfo - print Board Info structure
boot - boot default, i.e., run 'bootcmd'
boot_noos - boot User Program
boot_zImage - boot Linux 's zImage
bootd - boot default, i.e., run 'bootcmd'
bootelf - Boot from an ELF image in memory
bootm - boot application image from memory
bootp - boot image via network using BootP/TFTP protocol
bootvx - Boot vxWorks from an ELF image
chpart - change active partition
cmp - memory compare
coninfo - print console devices and information
cp - memory copy
crc32 - checksum calculation
date - get/set/reset date & time
dcache - enable or disable data cache
eboot - Run Wince Ethernet Bootloader(eboot)
echo - echo args to console
erase - erase FLASH memory
flinfo - print FLASH memory information
fsinfo - print information about filesystems
fsload - load binary file from a filesystem image
go - start application at address 'addr'
help - print online help
icache - enable or disable instruction cache
iminfo - print header information for application image
itest - return true/false on integer compare
loadb - load binary file over serial line (kermit mode)
loads - load S-Record file over serial line
loadx - load binary file over serial line (xmodem mode)
loady - load binary file over serial line (ymodem mode)
loop - infinite loop on address range
ls - list files in a directory (default /)
md - memory display
menu - display a menu, to select the items to do something
mm - memory modify (auto-incrementing)
mtdparts- define flash/nand partitions
mtest - simple RAM test
mw - memory write (fill)
nand - NAND sub-system
nboot - boot from NAND device
nm - memory modify (constant address)
ping - send ICMP ECHO_REQUEST to network host
printenv- print environment variables
protect - enable or disable FLASH write protection
rarpboot- boot image via network using RARP/TFTP protocol
reset - Perform RESET of the CPU
run - run commands in an environment variable
saveenv - save environment variables to persistent storage
setenv - set environment variables
sleep - delay execution for some time
test_zImage - test Linux 's zImage
tftpboot- boot image via network using TFTP protocol
usbslave - get file from host(PC)
version - print monitor version
wince [ram] - Run Wince from flash or ram
Thanks
