Thanks for all the great comments, I now understand why video bloggers love to make videos, especially when you get this kind of positive feedback within hours of releasing a new video
![Smiley :)](https://www.eevblog.com/forum/Smileys/default/smiley.gif)
What a lovely machine. Oldschool but compact. I thought that Jeol Company was from Japan. http://www.jeol.co.jp/en/corporate/outline/
Thanks, and yes that is correct, it is from Japan, I had to use a 20+ kg step down transformer for my 230 Vac line voltage to 100 Vac, and every time I plugged the power cord into the wall, it was a 50% probability of the circuit breaker tripping, just because of the inductance in the transformer (SEM was not turned on).
Do those position adjusters work using a magnetic coupling to avoid having a shaft seal?
I think it actually has shaft seals for a more direct physical connection, especially for the X-Y movement, but for the rotation I can not be sure since I never checked (it is hard to tell from the inside of the chamber). The resolution of the instrument is on the order of 10 nm, so the movement in all directions have to be super stable without hysteresis.
Would be nice to digitise the output for direct digital imaging - I wonder if at the slow scan rate, you could do it with a sound card input?
I have had many thoughts of digitizing the signal, it even has a BNC for the signal on the side. But I never had time to do it. You would need to DC couple the inputs of the sound card and possible offset the signal, the output voltage is in the order of 1-2 Volts if I remember correctly so no problems there. My estimation is that it draws one line in ca. 100 ms, and you would like to get at least 1000 px resolution vertically. So you need a 0.1 ms sampling time (10 kHz), which should be no problem for a sound card!
How heavy is it? I would imagine that it would be quite heavy.
300 kg, if that is heavy enough for you
![Wink ;)](https://www.eevblog.com/forum/Smileys/default/wink.gif)
