Author Topic: Video: How to make a simple, high-performance socket for a scope probe  (Read 5422 times)
Offline w2aewTopic starter
    • My YouTube Channel
This video shows a simple method to make a high performance (low inductance) socket to connect your oscilloscope probe to your circuit under test.  It is easily adaptable to different probe sizes/styles and circuit configurations.
FAE for Tektronix
Offline robrenz
  • Real Machinist, Wannabe EE
Re: Video: How to make a simple, high-performance socket for a scope probe
« Reply #1 on: September 18, 2013, 02:34:53 am »
Very nicely done w2aew, as always :-+
Offline marshallh
    • retroactive
« Reply #2 on: September 18, 2013, 03:26:59 am »
A+ sure beats trying to hold the probe on a small via bending over the spring tip just right... while trying to finagle the scope controls with the other hand!
Verilog tips
BGA soldering intro
Offline casinada
« Reply #3 on: September 18, 2013, 04:05:28 am »
Thank you  w2aew as usual your clarity to show and teach subjects is incredible :)
For more information on the subject everybody should watch Bob Pease (RIP) shows.
http://www.ti.com/ww/en/bobpease/
   (around 8:30 into the video )
« Last Edit: September 18, 2013, 06:49:37 am by casinada »
Offline BravoV
  • +++ ATH1
« Reply #4 on: September 18, 2013, 04:28:51 am »
Excellent video  :-+, thank you Sir !   :clap:
Offline ablacon64
  • Country: br
« Reply #5 on: September 18, 2013, 02:25:28 pm »
Very good! Thank you for the video!
Offline bronson
« Reply #6 on: September 23, 2013, 05:49:44 am »
Oh man, I did not realize Bob did videos...  I gotta catch up on that.
For some great discussion on low noise measuring, check out What's All This Ground Noise Stuff Anyhow, p. 88 in this pdf:
 http://www.ti.com/ww/en/bobpease/assets/www-national-com_rap.pdf
Edit: or go right to the original article with the same text but no picture of a probe in a coily socket: http://electronicdesign.com/boards/whats-all-ground-noise-stuff-anyhow
« Last Edit: September 23, 2013, 08:33:58 am by bronson »
Offline Galaxyrise
« Reply #7 on: September 29, 2013, 07:32:16 pm »
Thanks for the video! Inspired by this, I attempted to make some small loop tips for my probe such that the ground "socket" ended in a straight wire that would be a second probe tip, rather than soldering that ground socket to something. I had a lot of trouble with the plastic retaining ridge on my probe snagging the wire loops and deforming, causing the probe to have a loose fit.  So I went for something stiffer, and ended up with a finishing nail.  It was a lot more difficult to work to the correct shape, of course, but it holds that shape as I take it on and off.
I am but an egg
« Reply #8 on: September 29, 2013, 09:22:29 pm »
Nice ground spring adapter. I've also used a paper clip for the same thing, as it holds it's shape well after being formed.
FAE for Tektronix
Offline madshaman
  • ego trans insani
« Reply #9 on: October 01, 2013, 04:40:18 pm »
Do a youtube search for Bob Peace, you'll be happy.  Gave me many hours of bathtime entertainment (yes, I have a TV at the end of my bath connected to an Apple TV, not bragging, recommending a similar setup, you can read and watch tech videos and take a soak all at the same time, my gf thinks I'm nuts but loves me anyway)
To be responsible, but never to let fear stop the imagination.
