Welcome,
Guest
. Please
login
or
register
Did you miss your
activation email
1 Hour
1 Day
1 Week
1 Month
Forever
This topic
This board
Entire forum
Google
Bing
Home
Help
Search
About us
Links
Login
Register
Products
Test Equipment
Good probe for noise and ripple?
« previous
next »
Print
Search
Pages: [
1
Go Down
Author
Topic: Good probe for noise and ripple? (Read 2626 times)
AlanR
Regular Contributor
on:
March 23, 2014, 09:32:46 pm »
I just recently threw down $1000 for a Cal Test CT3688 active differential probe. Here is the datasheet:
http://disti-assets.s3.amazonaws.com/straightroadelectronics/files/datasheets/2023.pdf
You guys think I should have went with a different probe that may be better? I have searched, but the others had worst specs than this one.
Logged
robrenz
Super Contributor
Country:
Real Machinist, Wannabe EE
Re: Good probe for noise and ripple?
Reply #1 on:
March 23, 2014, 09:41:42 pm »
Isn't that 10X attenuation going to hamper seeing low level signals? Even if your scope has 0.5mV/div that will be 5mV/div after the probe. Is that going to work for you?
Logged
My video channel
https://www.youtube.com/playlist?list=PLRe7NGdsY7s6sOTsRahdb_sx2oDwGbh_O
AlanR
Regular Contributor
Reply #2 on:
March 23, 2014, 09:47:26 pm »
I can send it back. I need one that has low noise and low offset errors with 1% or better accuracy. I have a $3000 budget for one. If push comes to shove I'll just build a differential amp front end.
Logged
robrenz
Super Contributor
Country:
Reply #3 on:
March 23, 2014, 09:57:04 pm »
There are some nice units here
Logged
My video channel
AlanR
Regular Contributor
Reply #4 on:
March 23, 2014, 10:09:11 pm »
THANKS!! I have decided on the SIM910 preamplifier. Looks like it is time to send back the differential probe.
EDIT: eehhh, only 1 MHz bandwidth.
Last Edit: March 23, 2014, 10:17:37 pm by AlanR
Logged
w2aew
Super Contributor
Country:
I usTa cuDnt speL enjinere, noW I aR wuN
Reply #5 on:
March 24, 2014, 12:45:01 am »
If you have a late model Tek scope that uses the Tek-VPI probe interface, the TPP0502 is a 500MHz, passive probe that is only 2X attenuation - really nice for these types of measurements.
Logged
YouTube channel:
https://www.youtube.com/w2aew
FAE for Tektronix
nctnico
Super Contributor
Country:
Reply #6 on:
March 24, 2014, 12:56:14 am »
How about not using a probe and feeding the signal through a BNC or SMB connector directly into the scope?
Logged
Print
Search
Pages: [
1
Go Up
« previous
next »
Products
Test Equipment
Thanking...
EEVblog Main Site
EEVblog on Youtube
EEVblog on Twitter
EEVblog on Facebook
EEVblog on Odysee
