I just did a quick 10 minute test of the WFS210 with a function generator.......
Oh what a pity
![Sad :(](https://www.eevblog.com/forum/Smileys/default/sad.gif)
This unit could so easily be very good..... but boy does it have issues !
Fellow buyers of this unit... I think you may be returning them for a refund.
The very first time I tried connecting the unit to my HUDL it connected fine. Since then it has put up quite a fight. I will take you through a typical Wi-Fi connection experience...
1. Switch on WFS210 - unit boots and flashes connect LED
2. Wait for WFS210 to appear on Wi-Fi nodes on the Tablet
3. Select WFS210 node and wait for 'connected' to appear on tablet
4. Look at WFS210 to see if Link established LED is lit .... it is not
5. Start the WFS210 APP. APP starts but claims no WFS210 and goes to demo mode
6. Go into APP settings and deselect Demo tick box. Return to APP main screen.
7. The APP reports no WFS210 and goes into DEMO mode again.
8. Go back into the settings menu and deselect the Demo mode
9. Return to main screen and DEMO mode will appear again. But sometims also an IP address
Appears at the bottom of the screen.
10. Keep going round the loop deselecting demo mode and returning to the main screen until the APP eventually sees the WFS210 and the APP begins working. The link LED is also now illuminated.
11. Both input Channels are OFF by default. Select a channel and either manually or Auto set the timebase and voltage range.
Yes it is that much hassle. It appears that even though the tablet sees the WFS210, the APP does not !
Eventually it sees the unit and we can progress. Very annoying though.
A quick test using a function generator proved that the trigger operates and that the frequency and amplitude readings are accurate. Note that the amplitude measurement feature defaults to DC volts ! A DSO tends to be an AC display device and they go and default to a DC measurement mode ! Once you select P-P or RMS, all is well.
So far I have found the unit to be frustrating to use
The APP may look quite 'pretty' but it appears to be very poorly written and unreliable at finding the WFS210. Such a pity as the idea behind the unit is sound. The hardware looks reasonable, but the software.... oh the software
What idiot places a probe compensation signal contact on the underside of the case, rather than on the easily accessible front panel ? Oh and what idiot places the proble compensation contact hole adjacent to the units SSID reset button hole ! Daft buggers !
Do I keep it or send it back...... I will spend some more time with the unit but if things do not improve, it's useless and infuriating to use.
How on earth did this thing get released from Velleman R&D in its current state ? It's a joke.
Oh, in case anyone is trying to use Win 10 on a PC with the WFS210, I understand it is not compatible.
Fraser
