Author Topic: cheap DC-DC converter with external serial or USB control ?  (Read 188 times)
Offline JBealeTopic starter
My feeble searches for this have come up short. It seems possible, because of the existence of things like "DROK Buck-Boost Converter, 80W"  https://www.amazon.com/dp/B0BQBXMH67 for only $22. I have one of those, and it works satisfactorily for my needs. You can control both the voltage and the current-limit separately, using one digital control knob and some buttons. The adjustment response is slow: apparently they are driving the DC-DC block with a PID loop implemented in software that relies on the slow ADC (maybe 0.5 sec per update) that also drives the I and V display, so in response to a step change, you can observe the voltage and current bounce around for several seconds, before settling.
At any rate it's good enough for my project, and it is clearly using a MCU with strictly digital inputs; several switches and the push / turn rotary encoder control. I guess I could hack those, but I'm just wondering if anyone took the next step and offers a similar item with external serial port or USB port that accepts voltage and/or current setpoints. I understand "programmable power supply" is a standard item, but the models I know about are in a different price class, in exchange for better performance in ways I don't actually need. Given the existence proof of a $22 item, I was imagining a serial-control-capable version of the same thing might be only slightly more.
Online KungFuJosh
  • TEAS is real.
Re: cheap DC-DC converter with external serial or USB control ?
« Reply #1 on: June 21, 2024, 07:32:40 pm »
These are good: https://www.amazon.com/gp/product/B09B1NW9NH/
I use variations of that in my tube tracers. I have that one in my current tracer with the intent of controlling it over Bluetooth, but haven't tested that part out yet. It comes with USB and BT boards.
"I installed a skylight in my apartment yesterday... The people who live above me are furious." - Steven Wright
The following users thanked this post: JBeale
« Reply #2 on: June 21, 2024, 08:07:27 pm »
Great, that looks exactly like what I was thinking about, thank you!
The user manual that Amazon links to only mentions using a provided Windows program, but I see that full user control details are available in a nice review at
which describes a very usable python program that allows for all the control you probably need under script control from https://github.com/TheHWcave/DPS5005-control
(which is all I need) or if that's not enough, the modbus protocol register description provided in the documentation folder at
https://www.mediafire.com/file/1bwi72wovy10oe1/DPH5005_file_%25282017.11.08%2529.zip/file
« Last Edit: June 21, 2024, 09:27:02 pm by JBeale »
Online KungFuJosh
  • TEAS is real.
« Reply #3 on: June 21, 2024, 09:11:02 pm »
If I find the links, I'll share them, but people have gone crazy with that unit. I think there might even custom firmware for it somewhere. Do some googling and you might find it. There's all kinds of stuff out there.
