Author Topic: UT210E wrong amps in CONTINUITY stuck or 0L  (Read 790 times)
Offline marce002Topic starter
  • Country: ar
« on: May 07, 2020, 08:29:06 pm »
Hello all
I have an UT210E clamp meter that went wrong doing amps measurements in continuity DC, it shows an offset of around 4/5A when first set, (lever at DC 10A) at 2A DC shows fixed 0L always......,,,,,,  and also does not allow  me to (zero button) , and as i said it is even worse in the 2A !! setting which do nothing and shows  "0L"... when you can measure DV in 20A after achiving a ZERO with many RESET ZERO times , you can measure with a lot of offset..... eg  1A current is measured at around 650 mamps, . Similarly, a 4A current is shown at around 3A. |O
What can be wrong?
video with the issue:  https://youtu.be/Wrffkx4lpA0
« Last Edit: May 07, 2020, 08:34:16 pm by marce002 »
Online Fungus
Re: UT210E wrong amps in CONTINUITY stuck or 0L
« Reply #1 on: May 07, 2020, 10:54:34 pm »
Haven't you already started a thread for this half a dozen posts down?
  • Country: ar
« Reply #2 on: May 08, 2020, 05:46:43 pm »
Again
What is wrong with this clamp? I have a ut210E nice for small DC measurements. One day stopped working... 2A shows always OL and in 20A shows an offset of 5A!!! Until reset several time I can get 0amps but measure is wrong
Online Fungus
« Reply #3 on: May 08, 2020, 05:56:40 pm »
Again
See replies in the other thread you started...
Offline Simon
  • Global Moderator
    • Simon's Electronics
« Reply #4 on: May 08, 2020, 09:39:31 pm »
If you post the same thing over and over you will get banned! I have locked this thread.
