Doh! Managed to delete rather than edit my post!
The schematic shows a fuse and a power switch in one line. The other line leads to the transformer and the voltage selector switch. I would connect the Hot to the fuse/power switch line. It should be easy to trace the appropriate wire back to the fuse holder.
