i just took a few moments to re-install and still no luck
like before i have run Zadig and installed the driver but still no device shows in Pulseview
i've attached some screens and a log from pulseview, hopefully you can spot something?
sr: backend: libsigrok 0.6.0-git-2bd5d17/4:0:0 (rt: 0.6.0-git-2bd5d17/4:0:0).
sr: backend: Libs: glib 2.50.2 (rt: 2.50.2/5002:2), libzip 1.1.3, libserialport 0.1.1/1:0:1 (rt: 0.1.1/1:0:1), libusb-1.0 1.0.20.11003-rc3, libftdi 1.2.
sr: backend: Host: i686-w64-mingw32.static.posix, little-endian.
sr: backend: SCPI backends: TCP, serial, USBTMC.
sr: backend: Firmware search paths:
sr: resource: SIGROK_FIRMWARE_DIR environment variable not set, ignoring.
sr: backend: - C:\Users\DELETED\AppData\Local\sigrok-firmware
sr: backend: - C:\ProgramData\sigrok-firmware
sr: backend: - C:\Users\Public\Documents\sigrok-firmware
sr: backend: - C:\Program Files (x86)\sigrok\PulseView\share\sigrok-firmware
sr: backend: Sanity-checking all drivers.
sr: backend: Sanity-checking all input modules.
sr: backend: Sanity-checking all output modules.
sr: backend: Sanity-checking all transform modules.
srd: libsigrokdecode 0.6.0-git-cb67584/4:0:0 (rt: 0.6.0-git-cb67584/4:0:0).
srd: Libs: glib 2.50.2 (rt: 2.50.2/5002:2), Python 3.4.4 / 0x30404f0 (API 1013, ABI 3).
srd: Host: i686-w64-mingw32.static.posix, little-endian.
srd: Initializing libsigrokdecode.
srd: Adding 'C:\Program Files (x86)\sigrok\PulseView\share\libsigrokdecode\decoders' to module path.
srd: Protocol decoder search paths: - C:\Program Files (x86)\sigrok\PulseView\share\libsigrokdecode\decoders - C:\Program Files (x86)\sigrok\PulseView\share\libsigrokdecode\decoders
srd: Python system search paths: - C:\Program Files (x86)\sigrok\PulseView\share\libsigrokdecode\decoders - C:\Program Files (x86)\sigrok\PulseView\share\libsigrokdecode\decoders - C:\Program Files (x86)\sigrok\PulseView\python34.zip - C:\Program Files (x86)\sigrok\PulseView\DLLs - C:\Program Files (x86)\sigrok\PulseView\lib - C:\Program Files (x86)\sigrok\PulseView
sr: hwdriver: Scan found 0 devices (asix-sigma).
sr: hwdriver: Scan found 0 devices (chronovu-la).
sr: hwdriver: Scan found 1 devices (demo).
sr: hwdriver: Scan found 0 devices (dreamsourcelab-dslogic).
sr: hwdriver: Scan found 0 devices (ftdi-la).
sr: hwdriver: Scan found 0 devices (fx2lafw).
sr: hwdriver: Scan found 0 devices (gwinstek-gds-800).
sr: hwdriver: Scan found 0 devices (hameg-hmo).
sr: hwdriver: Scan found 0 devices (hantek-4032l).
sr: hwdriver: Scan found 0 devices (hantek-6xxx).
sr: hwdriver: Scan found 0 devices (hantek-dso).
sr: hwdriver: Scan found 0 devices (ikalogic-scanalogic2).
sr: hwdriver: Scan found 0 devices (ikalogic-scanaplus).
sr: hwdriver: Scan found 0 devices (lecroy-logicstudio).
sr: hwdriver: Scan found 0 devices (lecroy-xstream).
sr: hwdriver: Scan found 0 devices (ols).
sr: hwdriver: Scan found 0 devices (p-ols).
sr: hwdriver: Scan found 0 devices (rigol-ds).
sr: hwdriver: Scan found 0 devices (saleae-logic-pro).
sr: hwdriver: Scan found 0 devices (saleae-logic16).
sr: hwdriver: Scan found 0 devices (siglent-sds).
sr: hwdriver: Scan found 0 devices (sysclk-lwla).
sr: hwdriver: Scan found 0 devices (yokogawa-dlm).
sr: hwdriver: Scan found 0 devices (zeroplus-logic-cube).
sr: device: demo: Opening device instance.
sr: hwdriver: sr_config_list(): key 30002 (pattern) sdi 01942E60 cg A0 -> ['square', 'sine', 'triangle', 'sawtooth']
sr: hwdriver: sr_config_get(): key 30002 (pattern) sdi 01942E60 cg A0 -> 'square'
sr: hwdriver: sr_config_list(): key 30002 (pattern) sdi 01942E60 cg A1 -> ['square', 'sine', 'triangle', 'sawtooth']
sr: hwdriver: sr_config_get(): key 30002 (pattern) sdi 01942E60 cg A1 -> 'sine'
sr: hwdriver: sr_config_list(): key 30002 (pattern) sdi 01942E60 cg A2 -> ['square', 'sine', 'triangle', 'sawtooth']
sr: hwdriver: sr_config_get(): key 30002 (pattern) sdi 01942E60 cg A2 -> 'triangle'
sr: hwdriver: sr_config_list(): key 30002 (pattern) sdi 01942E60 cg A3 -> ['square', 'sine', 'triangle', 'sawtooth']
sr: hwdriver: sr_config_get(): key 30002 (pattern) sdi 01942E60 cg A3 -> 'sawtooth'
sr: hwdriver: sr_config_list(): key 30002 (pattern) sdi 01942E60 cg Logic -> ['sigrok', 'random', 'incremental', 'walking-one', 'walking-zero', 'all-low', 'all-high', 'squid']
sr: hwdriver: sr_config_get(): key 30002 (pattern) sdi 01942E60 cg Logic -> 'sigrok'
sr: hwdriver: sr_config_get(): key 50001 (limit_samples) sdi 01942E60 cg NULL -> uint64 0
sr: hwdriver: sr_config_set(): key 50001 (limit_samples) sdi 01942E60 cg NULL -> uint64 1000000
sr: hwdriver: sr_config_get(): key 50001 (limit_samples) sdi 01942E60 cg NULL -> uint64 1000000
sr: hwdriver: sr_config_list(): key 30000 (samplerate) sdi 01942E60 cg NULL -> {'samplerate-steps': }
sr: hwdriver: sr_config_get(): key 30000 (samplerate) sdi 01942E60 cg NULL -> uint64 200000
