No ! I did the voltage and frequency exactly as in the video!
Then why did you show something else in the video you shared? It shows 10µs/div timebase, while Rigol demonstrates things at 1 ms/div.
By the way, if you want to share more data: Can you please use still photos (or even better, PNG screenshots) instead of the video? Watching the shaky video made me dizzy, I wasted a lot of time watching you in search for the signal, and had a hard time reading the settings on the screen. Thanks.
In the video from Rigol, the model is 7000 and not 5000 as indicated in the title!
What makes you think that? The MSO7000 looks very different -- not only does it use a white enclosure, but also the screen size and connector layout are different from the MSO5000.
Please take a deep breath and review both, the Rigol video and your test.
