Author Topic: Used multimeter buyer's guide  (Read 35405 times)
Offline 1audio
Re: Used multimeter buyer's guide
« Reply #50 on: March 02, 2017, 06:16:52 pm »
The HP3456 (and 3455 ) are fine instruments. Also look at the Fluke 8502a and 8506A. I replaced an HP 3456 with a Fluke 8506A because I wanted the thermal AC converter and the 1 MHz accuracy. I got 7 1/2 digits in the process. But these are all large metrology instruments and not well suited to the constant change of tasks that a benchtop service instrument needs to deal with. For value a Fluke 8810 for less than $100 on ebay is hard to beat. Very fast and straightforward to work with. A Fluke 8860 is also well suited to benchtop work. Really better than the Keithley 2015 I replaced it with. I will probably revert soon.
Offline crazyguy
« Reply #52 on: March 03, 2017, 08:36:35 am »
I see a bunch of these AD584 voltage reference modules on ebay for under $3
The pcb looks clean.  I like it.  Thing is I am guessing they don't measure them with their 6 digit calibrated meters there and record the values onto a label :)   But wow these are sweet.  I could design and 3d print a case for it (and share the file on thingiverse.com for people to download and print).   Trick is getting it measured.  Maybe my local electronics shop would measure it for me .. friends with the owner.
I could use this pcb as part of a larger, affordable, reference unit.  Throw in some resistors for resistance checking.  Not smart enough yet to build a current reference.  But if I got help with that I could make a case that houses all three and share the CAD file with everyone on Thingiverse.  Could even print out a few cases for people if I got some help with the design.
[I suppose I should create a separate thread for this.. maybe I am getting too off topic here?  Sorry OP.]
If you want to buy this AD584 module, some seller do not give you the calibration sheet.
The original seller is on Taobao
https://item.taobao.com/item.htm?spm=a230r.1.14.22.IXBCJG&id=525111728557&ns=1&abbucket=18#detail
You can download the calibration spreadsheet in here
http://pan.baidu.com/s/1cdpRbC
password?07np
Offline JenniferG
« Reply #53 on: March 03, 2017, 08:46:02 am »
Thanks I ended up buying a 584L.  The guy allegedly measures each individually and records the measurement for each of the voltages.
I'll compare to local electronics store meter to verify. I am sure he has a high digit one well calibrated.
Test Equip: GDM-8251a, UT61E, Probemaster, Tektronix 2225
Power Supplies: GPD-3303S (w/o overshoot problem)
Soldering Station:  Hakko 926
Offline usagiTopic starter
Keithley 2015 THD Notes
« Reply #54 on: March 22, 2017, 06:09:04 am »
Dozens, maybe hundreds cheaply available from this ebay seller
« Last Edit: March 22, 2017, 06:35:03 pm by usagi »
« Reply #55 on: August 03, 2017, 02:48:08 am »
« Last Edit: April 01, 2018, 09:25:45 pm by usagi »
Offline cellularmitosis
« Reply #56 on: August 29, 2017, 05:47:28 am »
Thank you so much for organizing this list!  I had started doing this myself before I found your list.
Can you add an entry for the Datron 1071?  feedback.loop has featured it in several videos.
https://youtu.be/jcCC867gKXE
A little later in the video he compares it against a HP 34401A.
LTZs: KX FX MX CX PX Frank A9 QX
Offline Neomys Sapiens
« Reply #57 on: August 29, 2017, 11:17:22 pm »
Ok, this is useful (the OP).
We should extent the List and write it forth!
Country/Market is GER for the following:
Unigor 6E 50...200€ unchanging over several years, depending on state and assurances given.
Schlumberger 7151 (5.5dig LCD RMS IEC+RS232) 'computing multimeter' 150€ without but fit for cal. (else?)
Prema 6001 (in 2012), 6.5d RMS LED-dot IEC) internal scanner,  with unofficial calib. 400€ else 300...600€
« Reply #58 on: August 30, 2017, 04:37:50 am »
added new data.
but would you really recommend a hobbyist pick a unigor 6e over a similarly priced HP 3457A ?  :-DMM
« Reply #59 on: August 31, 2017, 01:22:14 am »
I recommend nothing. Except having always at least a DMM and an analogue meter. My preference is having the right multimeter for any application, task, and environment.
« Last Edit: August 31, 2017, 01:24:44 am by Neomys Sapiens »
« Reply #60 on: August 31, 2017, 07:50:12 pm »
And another remark: it is not very likely to pick up a HP 3457A for 200$ anywhere but in the US and from what I have seen in the Bay and elsewhere, even there that seems to be the low end of the range. That was behind my mention of market/area and giving a price range. The 200.- for the Unigor would have been used, within spec., tested, with warranty, return possible.
The ranges given exclude desolate examples and those obviously needing work.
« Reply #61 on: February 05, 2018, 07:06:48 am »
Fluke 8845A/8846A review
Fluke 8845A/8846A Product Page
Offline alm
« Reply #62 on: February 10, 2018, 12:04:55 pm »
Some suggested changes to the table in your first post:
Keithley 192: ACV is optional, no current.
Keithley 2015: Very similar to Keithley 2000.
Datron 1081: there is no option for current measurement, only ACV and resistance.
Datron 1082: Datron 1081 with resistance, ACV and GPIB.
Offline Vtile
  • Ingineer
« Reply #63 on: February 10, 2018, 11:13:39 pm »
There could be room for Keithley 197A and 197, 5½ digit "Microvolt DMM". Options were GPIB and battery operation IIRC.
Online rsjsouza
  • Eternally curious
    • Vbe - vídeo blog eletrônico
« Reply #64 on: February 11, 2018, 12:19:24 am »
Keythley 191 is a very good 5-1/2 (200000 counts) manual range DMM that can be had for quite a bargain and has a high quality service manual that I scanned and uploaded to KO4BB site. It does not have current and ACV is optional.
Racal Dana 5001 is also a nice 5-1/2 (220000 counts) autorange DMM that can also be had for good prices. It also has service manuals available and features current.
Both meters use standard parts and have published calibration procedures.
« Last Edit: October 11, 2019, 08:54:49 pm by rsjsouza »
Offline ogdento
« Reply #65 on: October 11, 2019, 05:56:00 pm »
thanks for this great thread for finding a 5 1/2 digit meter!  I'm waffling between a Keithley 197/197a or an HP 3478a...
rsjsouza, did you mean Keithley 197 - not 179 - was the 5 1/2 digit model (I thought the 179 was only 4 1/2)?  Also, in an earlier post I think you said you got some hp3478a meters... how do you like them?
there's a really nice looking Racal Dana 5001 online now, but from what I've read on the forum it's more temperature sensitive than the 3478 (and it's less counts), and it has no gpib - not the end of the world but gpib would be fun to play with.
The following users thanked this post: rsjsouza
Offline don.r
« Reply #66 on: October 11, 2019, 06:34:15 pm »
197/197A are great meters. 200000 count 4-wire measurement, 200uA/200mV range with 1nA/1uV resolution optional GPIB, data logging, relative measurements, db mode. 0.007% or better on DCV and 0.01% on most ohm ranges. Usually go for less than US$100 + shipping. All through hole for easy repair. I picked up and repaired its little brother the 179A 4.5 digit meter. Cost me $19 + shipping and a $2 op amp.
Offline ogdento
« Reply #67 on: October 11, 2019, 07:53:14 pm »
hey don thanks for the input on the Keithleys... 19 bucks for a 179a, holy smokes!  i read modemhead's 197a post the other day and he got his for 32 shipped (5 years ago).  those are crazy deals for that kind of spec!!
Offline don.r
« Reply #68 on: October 11, 2019, 08:36:38 pm »
Anything under $100 for a 197/A or under $50 for a 179/A is a good deal IMO. Real steals seem far and few between these days.
Online rsjsouza
  • Eternally curious
« Reply #69 on: October 11, 2019, 09:01:21 pm »
Sorry, I fixed my post. I meant 191. The Keithley 197 is a more featured version with a LCD screen.
You are correct; I have a pair of 3478As at home and they are excellent meters as well - however, their displays are really terrible in comparison but they feature GPIB and 300k counts.
My Racal Dana 5001 stabilizes quite well after 20~30 min - it runs on an air-conditioned room and has an excellent LED display (like the 191 above). It is my workhorse at work.
I think I saw the eBay auction you are referring. The second photograph the person put the voltage reference to the force jacks of the 4-wire ohms, not the actual voltage inputs...  :palm:
(I have done that and no damage was done to the meter)
By the way, this week I uploaded a high quality service manual for the Racal Dana to the KO4BB site. I see they also added my 300dpi scans of chapter 6 with the mechanical and schematics drawings, so you can have a nice reference.
http://www.ko4bb.com/getsimple/index.php?id=manuals&dir=Racal/Racal_Dana_5001
« Last Edit: October 11, 2019, 09:19:10 pm by rsjsouza »
Offline ogdento
« Reply #70 on: October 11, 2019, 10:11:10 pm »
ha thanks for the racal notes... I thought that shot showing their power supply looked funny!!  I noticed that the voltage source is set to 9.9-something volts and the meter is showing 9.7988, then thought "hey is that even connected right?" ;)  I wish it had gpib!
Offline EEVblog
« Reply #71 on: October 12, 2019, 01:06:22 pm »
Fluke 8840A for AU$100
https://www.ebay.com/itm/Fluke-8840A-Digital-BenchTop-DC-MultiMeter-5-1-2-Digit-Display-50-60-400-Hz/254385404407
The following users thanked this post: ogdento
Offline don.r
« Reply #72 on: October 12, 2019, 02:51:34 pm »
US$100 + Does Not Ship To United States (for once!)
Online rsjsouza
  • Eternally curious
« Reply #73 on: October 12, 2019, 04:08:30 pm »
Huh? To me it shows that it ships from Fullerton, California... With no restrictions to where I live.
« Reply #74 on: October 12, 2019, 04:23:43 pm »
For me, doesn't matter where they ship or don't; no AC-09, no sale  ^-^
