@nctnico - that's actually not true. Admitted, especially at low frequencies (sub-10MHz range), there are very strong harmonics present in most TG output signals, but same is true for many RF signal generators. This is the result of the output amplifier not really being designed for these low frequencies. Since the signal is synthesized by mixing two pretty decent sine wave signals, the difference of those shouldn't (and doesn't) contain that much harmonics, hence I'ld consider a TG signal (harmonics-wise) suitable for bandwidth testing of an oscilloscope, at least much better so than one of these ADF4351 based "el-cheapo" sources. But if it's comfortable to use a TG for such an application, is written on another page...
A hint for the OP: Once in a while, an R&S SM300 can be found inexpensively (though usually with a broken PA which is quite fixable). These generators perform much better than the initially mentioned AimTTi instrument and are very well suited for other test jobs as well. Yet, you've got to be patient and put some work into the device...
