Author Topic: Use Picoscope 6 Automotive software with any model picoscope (new method)  (Read 7799 times)
Offline anonymousTopic starter
Picoscope 6 Automotive Patch
FYI: This is NOT the old method of deleting the oem.dll file. This new method I created keeps the software 100% intact, which means you have access to the Waveform Library, Lowpass Filtering, Channel Labels, etc, that were all missing with the old method. This new method also does not require you to have the non automotive version of Picoscope 6 installed (though it's fine if you do).
How to:
  • Download the RAR file from: https://siasky.net/AAB-JHlNQGkTjuPcOalFoFEBvWJbruHOnC38bGAK0vRZxQ
  • Extract all files from the RAR to your Picoscope 6 Automotive installation directory and choose OVERWRITE to replace the original files (default location C:\Program Files (x86)\Pico Technology\PicoScope6 Automotive)
  • Plug in your picoscope and start Picoscope 6 Automotive
  • ENJOY!
EDIT: The Lowpass Filter wasn't showing up and working like I thought. I made a modification and repacked the RAR. Lowpass Filtering should now show up and work.
« Last Edit: February 14, 2021, 03:42:08 am by anonymous »
The following users thanked this post: egonotto, thm_w, vmax, Ricky25, Bluegizmo83, PicoUser2022
Offline PicoUser2022
Re: Use Picoscope 6 Automotive software with any model picoscope (new method)
« Reply #1 on: February 12, 2022, 03:23:59 am »
Worked great!
Offline maxxy_ma
Hi
Can this file be reuploaded please?
Or, maybe someone can share it with me?
Thanks a lot
Offline kollarik
How to:
  • ENJOY!
Can you make this work with version 7?
Thank you!
« Last Edit: July 02, 2022, 04:37:45 pm by kollarik »
Offline dzmit1
« Reply #4 on: November 15, 2022, 10:25:11 pm »
Hi
Thanks a lot
Online coromonadalix
« Reply #5 on: November 16, 2022, 01:51:31 am »
same here ... would like to have it
Offline egonotto
« Reply #7 on: November 24, 2022, 12:28:51 am »
Hello,
uinfortunately does not work:
This portal is processing requests only from registered users.
If you uploaded this file and want to allow access to users without an account you need to visit Dashboard > Settings > Developer Settings tab and set up a Sponsor API Key for specific Skylink(s). This is useful if you want to upload image, video or other content and display it on your site for example.
See https://github.com/DangerCZ/skynet_migration_guide for more information.
Best regards
egonotto
« Last Edit: November 24, 2022, 03:15:44 am by egonotto »
Offline Langtree1989
Hello, is it possible anyone can send me this file?
Offline firewalker
  • Country: gr
Can someone provide the files?
Alexander.
same here
Offline firewalker
  • Country: gr
I came across a working link, and decided to test just out of curiosity. It works. But... I was unable to login to the Waveforms Library (picoscope will crash) and Picoscope will remove the Waveform Library for version 6  in mid July 2023.
mega.nz/file/0dgVyByR#pNWMNJpo29SWat7L1-9170qhPq-UwUnHkuYFj6xr1aY
The following users thanked this post: egonotto, coromonadalix
